1 members (TooMany2count),
119
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25058 03/04/2004 12:13 AM | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | i have a 50 1/2 ton and am subframing this weekend after many long months of prep. what should i do about the brake and gas. i'd like to use a brake booster | | |
#25059 03/04/2004 2:59 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | The stock frame doesn't get cut that far back so the stock pedal assembly is fine. You can then either purchase the kits that use the stock pedal or go with a booster/master cylinder unit on the firewall.
Joe
#25060 03/04/2004 3:06 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I purchased a "universal" gas pedal unit with polished aluminun that fastened to the firewall and works great. For the brakes I used a stang 11 booster and master cyl. I did have to fabricate a bracket to hold it and actually made the pedal but it sure works good UNDER THE FLOORBOARD where the original was and it left the firewall nice and clean under the hood. ITs been 5-6 years and no problems. Think about it. I'm sure some others around close have done the same thing that you could look at. | | |
#25061 03/04/2004 3:27 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Have you done a search for "booster" I remember a long while ago one of the members drawing up some diagrams for using the original pedal and a booster. I can't remember who it was. Hopefully one of the other member can.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#25063 03/05/2004 5:57 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've used a booster from a '75 Chevy truck and a master for a '66 Catalina (4 wheel drum system)and mounted them under the floor in the stock location. There was a lot of modifying involved but it was worth it. The gas pedal I used was from the same truck. It was a cable type that is simple to install. | | |
