1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#24814 01/29/2005 9:18 PM
I just disassembled, cleaned and painted each and every leaf spring. Before reassembling these, what if anything should I put between the leaves to prevent squeeking when they are in use? I've seen plastic inserts on other brands or maybe some clear grease to lubricate them. Maybe I should wait to see if they even make noise. Has anyone used anything to "separate" the leaves to prevent paint wear and noise?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#24815 01/30/2005 9:46 PM
I saw an episode of car restoration on diynet. They smeared wheel bearing grease all around the springs then wrapped them with duct tape and drove the car. This forced the grease between the springs. easy
#24816 01/31/2005 4:15 AM
I've still got all of the springs apart, so if grease was the answer (which I'm kind of leaning towards), I could do it before reassembly. I have some almost clear silicone paste I was thinking about using but wanted to see if there was anything "cleaner" out there.
Resto44, what's with being registered for a years and half with only 1 post, shy or the quiet type? Just kidding and thanks for the reply. What parts are you from?
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#24817 01/31/2005 4:22 AM
Those little Teflon buttons used by hot rodders work nice. One on each end so the springs slide against each other and won't squeak.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#24818 01/31/2005 5:34 AM
Do not use any type of grease between the leafs as it attracts dirt and will cause the springs to actually become stiffer.
The old model A's did use grease and were wrapped in a burlap type material but these are really a mess to deal with.
Best is to bevel the ends of each leaf with a grinder so as not to allow the leading edge of that leaf to dig into the adjacent leaf. That's really all that is necessary. Then assemble and paint the entire spring pack as a unit.
You can use the poly spring liner between leafs but in trucks it sometimes makes the suspension too soft.
OK I'll leaf off on this discussion here............... :-)
#24819 01/31/2005 7:01 PM
Junior Member
Junior Member
My 66 rolls royce has grease between the leafs, they are then wrapped in leather.
Don Meyer-PhD,mech engr
#24820 01/31/2005 7:16 PM
I have thin teflon strips between the leaves ,, needed to put better shocks on to tie it back down to the road ... grin ... is great now.
#24821 01/31/2005 7:24 PM
