| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Hi gang! On my 62 c-30, the old speedometer had the needle broken off and the speedometer made so much noise I finally just pulled the cable out of it. I have since aquired a cluster out of a 62 2-ton and put the speedometer from it into my c-30. I figured the speed would be 10 or so mph off, which it was, but after driving a few miles it started making the same loud noises (sorta like an air body saw makes) and the speed jumped from 35 up to a range of 50 to 70 mph. I was probably doing about 40ish. Also, when I slow down, the noise stops and the needle starts acting normal again. Any ideas? Thanks, David :confused:
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | sometimes the inner cable itself is broke down by the transmission. Or it needs a little cleaning and lube. | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Oly, Sounds like a good cleaning and new lube with white (light weight) grease should do the trick. Put some grease on the piece that fits into the back of the speedo-- Good luck. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The new cables are around 12-15$ and most flaps should have them on the shelf. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've ran into this problem before and "believe it or not" it was caused by the end on the speedometer cable. The end that goes into the speedometer. The end "somehow" got worn down and depending on the speed it acted different and the needle bounced. I put in a NEW cable and had the same problem. Then I thought the speedo head was worn.....wrong. I took it over to my "guage pal" and when we checked it with a set of dial indicators found that even the new cable end was smaller than the stock which he carried. I had him cut me a new one that is the right size on the end and now the speedo works very nice. Its still a good idea to clean and lube though. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree a good grease of the cable & the back of the speedo is first off. A lot of the bigger trucks had a little adapter on the outlet of the trans. to calibrate the speedo. Sometimes you have to take it apart & grease it inside. If the speedo was right before it should be right with the other head. All speedo,s were set for 1000 rev,s per mile. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | I had a 62 impala that the needle jumped and noisy, pulled it and lubed it then it was fine.of course i did this after I was on a trip on the interstate and the state cop put his arm out the window and shook his finger at me....I had no idea how fast i was going but i slowed down a bit! | | |
