2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#241402 09/28/2007 3:25 AM
Hi gang!
On my 62 c-30, the old speedometer had the needle broken off and the speedometer made so much noise I finally just pulled the cable out of it. I have since aquired a cluster out of a 62 2-ton and put the speedometer from it into my c-30. I figured the speed would be 10 or so mph off, which it was, but after driving a few miles it started making the same loud noises (sorta like an air body saw makes) and the speed jumped from 35 up to a range of 50 to 70 mph. I was probably doing about 40ish. Also, when I slow down, the noise stops and the needle starts acting normal again. Any ideas?
David :confused:
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
#241403 09/28/2007 4:56 AM
sometimes the inner cable itself is broke down by the transmission. Or it needs a little cleaning and lube.
#241404 09/28/2007 6:25 PM
Oly, Sounds like a good cleaning and new lube with white (light weight) grease should do the trick. Put some grease on the piece that fits into the back of the speedo--
Good luck.
#241405 09/28/2007 6:46 PM
The new cables are around 12-15$ and most flaps should have them on the shelf.
My 1953 Chevrolet
1947.1 Gallery
#241406 09/28/2007 8:23 PM
I've ran into this problem before and "believe it or not" it was caused by the end on the speedometer cable. The end that goes into the speedometer. The end "somehow" got worn down and depending on the speed it acted different and the needle bounced. I put in a NEW cable and had the same problem. Then I thought the speedo head was worn.....wrong. I took it over to my "guage pal" and when we checked it with a set of dial indicators found that even the new cable end was smaller than the stock which he carried. I had him cut me a new one that is the right size on the end and now the speedo works very nice.
Its still a good idea to clean and lube though.
#241407 09/28/2007 9:08 PM
Riding in the Passing Lane
I agree a good grease of the cable & the back of the speedo is first off. A lot of the bigger trucks had a little adapter on the outlet of the trans. to calibrate the speedo. Sometimes you have to take it apart & grease it inside. If the speedo was right before it should be right with the other head. All speedo,s were set for 1000 rev,s per mile.
1972 Chevy c10 Cheyenne Super
#241408 09/29/2007 11:55 AM
I had a 62 impala that the needle jumped and noisy, pulled it and lubed it then it was fine.of course i did this after I was on a trip on the interstate and the state cop put his arm out the window and shook his finger at me....I had no idea how fast i was going but i slowed down a bit!
