Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (crenwelge, Gdads51, C10 - C90 Bill), 115 guests, and 2 robots.
Topics128,290
Posts1,058,557
Members48,491
I
I Offline
or steel that is one piece.... I dont want to take the time to fill mine if there is someone out there
Anonymous
Unregistered
Anonymous
Unregistered
Never seen one - metal or fake.
If you do decide to fill yours I would suggest doing it while the hood is installed on the truck. Tack the halves together about every 5 inches then lay a strip of metal in the valley and tack that in very slowly to prevent warping. Grind the tacks down and smooth out with filler. Good luck.
Yup as Houston stated ...PO filed mine with bondo , all cracked down the center ..you will need to weld in a filler
1952 Chevy Shortbed
Photos in Photobucket
Jim,
See if these guys have what you want,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
i beleive superior glass work makes a hood or in the prossess of getting production going. i know they make glass rear fenders and running boards. iw ill ask my freind that works there tonight and post again
gotta love old trucks
superior glass works in molalla oregon is suposed to make a glass hood. try them her email is www.superiorglass.net. good luck
I
I Offline
thanks for the info.... not sure if I want to spend $500 or just fill mine.
