| | | Forums66 Topics128,285 Posts1,058,533 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 69 | or steel that is one piece.... I dont want to take the time to fill mine if there is someone out there Thanks | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Never seen one - metal or fake.
If you do decide to fill yours I would suggest doing it while the hood is installed on the truck. Tack the halves together about every 5 inches then lay a strip of metal in the valley and tack that in very slowly to prevent warping. Grind the tacks down and smooth out with filler. Good luck. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Yup as Houston stated ...PO filed mine with bondo , all cracked down the center ..you will need to weld in a filler | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Jim, See if these guys have what you want, Scott | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | i beleive superior glass work makes a hood or in the prossess of getting production going. i know they make glass rear fenders and running boards. iw ill ask my freind that works there tonight and post again
gotta love old trucks
| | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | superior glass works in molalla oregon is suposed to make a glass hood. try them her email is www.superiorglass.net. good luck
| | | | | Joined: Mar 2007 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 69 | thanks for the info.... not sure if I want to spend $500 or just fill mine. | | |
