| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Wonder if any of you have found a better method than the tooth brush and old rag method of degreasing the the front brake drum and backing plate too get it ready for paint? I plan also to use the electrolysis method to derust because it seems to work better on parts that have been degreased first. Any suggestions??? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Soak it in mineral spirits???? Mineral spirits is cheap by the gallon. Get a plastic dish pan large enough to hold the drum & fill it with mineral spirits. Work it over with a stiff solvent brush every so often. I have a solvent tank but you probably don't want to pay that much.
| | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | I have a parts washer tank from Harbor freight but Not sure what kind of solvent to put in it that want damage the pump.And its a 20 gallon tank so your right not sure I would want to invest in that much cleaning solvent for just two hubs. What about the Castrol Superclean degreaser or Simple Green Degreaser I have a small power washer 1700psi would this be a option or a waste of time? Thanks again for your responses | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Wipe out the major glob of grease with a rag over a stick or screwdriver then hit it with your pressure washer. Should remove all the grease, if you need to, wipe the exces with a rag soaked with solvent. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | I grabbed something called Purple Power from Advance Autoparts the other day. It was on a promo sale at $4.50 a gallon. It seemed to work a whole heck of a lot faster and better than Simple Green on the items I cleaned: an old transmission caked in about 1" of grease, an old engine in similar condition, another engine that probably had more oil on the outside than inside the oilpan. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have a regular parts washer and solvent.
I usually use a putty knife for the heavy grease, then pressure wash.
If you just want it cleaned up and in paint (cheap), you can wash it in hot soapy water (I use Dawn) and rinse. Dry it off and when completely dry, wipe it down with some wax and grease remover (prep) and then paint it with some Iron Guard equipment enamel from an implement dealer. Iron Guard technically doesn't need primer over bare metal. You can get it in a rattle can, quarts or gallons.
If you are going high tech paint on these parts, putty knife, pressure wash, bead blast and then prime and paint.
I've used the Purple Power before. Not bad for a water based degreaser.
FYI - Pressure washers are great for parts, but they can get messy too. You need a good cement surface to do it on too. Also, the grease will have a tendancy to fly every where else and stick to what ever is close. Not good next to wife's car or the house, or the neighbors house/car. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have used purple power many times, and it works great before pressure washing.
If I have a lot or really nasty of stubborn stuff I will take the parts to the local automotive machine shop and put them in the "hot tank" an automated parts washer with a powerful and hot solvent. Often the paint is removed as well as the grease.
Grigg | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Go to the local coin car wash, and soak the parts with the "tire & engine cleaner" spray. Let them sit a few minutes, then use the high-pressure soap spray, followed by a clear water rinse. Do it late at night, as some car wash managers get really testy about washing grease down their drains! Jerry
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I use oven cleaner on the really slimy stuff. I also have access to a hot tank at work which is just an enclosed steam cleaner with an anti-rust alkalie. See what it would cost to run them through your local shops parts cleaner, Scott | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | throw them in the corner and install disc brakes! if drum brakes are so great they would still be using them. if you ever experienced "brake fade" and lived to tell the story you will understand, pretty hairy going downhill pulling a loaded car trailer and you lose your brakes. never happened with any of my rigs that had disc's on front. and gotta love those "single master cyl." just my 2 cents worth | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | macs brake cleaner sold at napa tryed 3 brands just to see it cleans things up fast it has napas name but says its made by macs | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | If it don't come clean with Super Clean it don't come clean. It's worked great for me in the garage and elsewhere. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | At the cost of new drums(on some models), it may be cheaper and easier to buy new ones. My 59 and 65 trucks are $24 each at the local parts store. | | | | | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Castrol Super Clean and Oven Cleaner work Wonders. As of now I am using this on my rear drums, backing paltes axles and will let it soak and power wash ut tomorrow am.
just my 2 cents
Birge | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I AM A FIRM BELIEVER ...in Castrol Super Clean ..if ya use it straight wear rubber gloves ...it is hard on the skin ...but IT WORKS ! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I use a 5 gallon bucket full of red devil lye. You can leave the parts in there for months on end if you have to, but they will come out completely degreased. So will your hands, if you dip them in. Use gloves.
Lye is cheap, not a fire hazard, and safe to the environment once diluted.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | 4ontheFloor: I'm in Salem and have been looking for some lye. Where did you find it? | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | Originally posted by Focus: I have a parts washer tank from Harbor freight but Not sure what kind of solvent to put in it that want damage the pump.And its a 20 gallon tank so your right not sure I would want to invest in that much cleaning solvent for just two hubs. What about the Castrol Superclean degreaser or Simple Green Degreaser I have a small power washer 1700psi would this be a option or a waste of time? Focus, Go to your fuel distributor and get 15 gallons of Varsol. Also known as Naptha, it's cheap and I use it in my Harbor Freight parts washer. Most mechanic shops use it too. Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | |
