8 members (TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall, Tyler Watts),
138
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | Is the dash factory welded to the firewall or is it just bolted. I see bolts on the side but wasn't sure about the firewall. Thanks in advance. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 28-32 spotwelds along the bottom of the windshield. | | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | Yikes! Kiss that idea goodbye. The previous owner has some small speakers mounted under the oval center vent in the dash and i could figure out how to he got em in there. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | This question was just answered 2 days ago. Try the search feature. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | badriand - play with the search feature, as cletis said... the small link under the 'post new topic' icons up top. this explains how to use the bolt forums: http://www.stovebolt.com/forum/gloveguide/manual.html enjoy the 'bolt! don't mind cletis, he's a good guy, just a lil grumpy sometimes. -W | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | badriand, I am going thru the same thing with my 65. The dashboard looks ike it needs painting,so I was hoping it would be easy to take it out and paint it.I got out some rubbing compound and cleaned about half of it up,and it looks pretty good. So maybe with a couple of rubbing compound treatments and a good polishing it will look OK.Good luck with your 66. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by badriand: Is the dash factory welded to the firewall or is it just bolted. I see bolts on the side but wasn't sure about the firewall. Thanks in advance. Now, back to your question. Why do you need to remove it? Did someone hack it up and it looks bad? They sell patch panels and smoothing panels for the radio area or I have some used pieces I've pulled while scrapping. Scott | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We run into the problem of people that have the painting and upholstery all done and then decide their dash looks scruffy. Scroll down page to first pic (black 53 ford 4dr) at http://s32.photobucket.com/albums/d41/coilover/ The painters plastic is about $15 at Home Depot and the aluminum foil is used to quickly cover all the irregular shaped stuff. Get a couple rolls of masking tape, allow a half day for masking, sand any areas needing it, clean, clean, and reclean, prime and paint. It will look factory and alot less time than removal.
Evan
| | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | I forget about the search function. No biggie , will try and remember next time. Previous owner hacked away to install a radio (hate when they do that) and install speakers on top but they are under the center vent. I couldn't figure how he got them in there becasue they are screwed from the top but looks like he build a contraption and then installed it from underneath. I was wanting to pull out fix, sand down repaint but i will just tape off and work it. Thanks guys. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | badriand, Do you have a picture of what you need? I have a radio section cut out of a 64 dash if you want to weld in a patch. I would like to see the speaker contraption too, Scott | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | badriand - no problem... glad yer here. http://www.americanclassic.com has a patch panel if you need it: RAD-33 1964-66 Dash radio panel, black, Chevrolet or GMC, with cutouts for radio panel and knobs, ashtray and heater controls, 17-1/4 inches wide x 10-7/8 inches high with 2-1/2 inch lip on top of dash panel ---- -W | | | | | Joined: Oct 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 62 | My dash looked the same way, I had to pull the fan box and a brace under dash to get at crappy Woolworth's speaker under the dash.I figure with the winsheild out, I will be able to weld it up. All those spot welds pretty much garauntee's most dashes are "original to the truck".
I see a GM truck in your future!
