3 members (FishinToms53, Gdads51, Gray_Ghost), 80 guests, and 0 robots.
Topics128,052
Posts1,055,740
#237227 07/13/2007 11:46 PM
Junior Member
Junior Member
Is the dash factory welded to the firewall or is it just bolted. I see bolts on the side but wasn't sure about the firewall. Thanks in advance.
#237228 07/13/2007 11:56 PM
28-32 spotwelds along the bottom of the windshield.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#237229 07/14/2007 12:05 AM
Junior Member
Junior Member
Yikes! Kiss that idea goodbye. The previous owner has some small speakers mounted under the oval center vent in the dash and i could figure out how to he got em in there.
#237230 07/14/2007 5:22 AM
This question was just answered 2 days ago. Try the search feature.
#237231 07/14/2007 11:48 AM
Socket Breaker
Socket Breaker
badriand - play with the search feature, as cletis said... the small link under the 'post new topic' icons up top.
this explains how to use the bolt forums:
http://www.stovebolt.com/forum/gloveguide/manual.html
enjoy the 'bolt!
don't mind cletis, he's a good guy, just a lil grumpy sometimes. grin
-W
#237232 07/14/2007 4:11 PM
badriand, I am going thru the same thing with my 65. The dashboard looks ike it needs painting,so I was hoping it would be easy to take it out and paint it.I got out some rubbing compound and cleaned about half of it up,and it looks pretty good. So maybe with a couple of rubbing compound treatments and a good polishing it will look OK.Good luck with your 66.
#237233 07/14/2007 4:48 PM
Quote
Now, back to your question. Why do you need to remove it? Did someone hack it up and it looks bad? They sell patch panels and smoothing panels for the radio area or I have some used pieces I've pulled while scrapping.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#237234 07/15/2007 3:19 AM
We run into the problem of people that have the painting and upholstery all done and then decide their dash looks scruffy. Scroll down page to first pic (black 53 ford 4dr) at http://s32.photobucket.com/albums/d41/coilover/
The painters plastic is about $15 at Home Depot and the aluminum foil is used to quickly cover all the irregular shaped stuff. Get a couple rolls of masking tape, allow a half day for masking, sand any areas needing it, clean, clean, and reclean, prime and paint. It will look factory and alot less time than removal.
Evan
#237235 07/17/2007 8:19 PM
Junior Member
Junior Member
I forget about the search function. No biggie , will try and remember next time. Previous owner hacked away to install a radio (hate when they do that) and install speakers on top but they are under the center vent. I couldn't figure how he got them in there becasue they are screwed from the top but looks like he build a contraption and then installed it from underneath. I was wanting to pull out fix, sand down repaint but i will just tape off and work it. Thanks guys.
#237236 07/17/2007 11:19 PM
badriand,
Do you have a picture of what you need? I have a radio section cut out of a 64 dash if you want to weld in a patch. I would like to see the speaker contraption too,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#237237 07/18/2007 10:07 AM
Socket Breaker
Socket Breaker
badriand - no problem... glad yer here.
http://www.americanclassic.com
has a patch panel if you need it:
RAD-33
1964-66
Dash radio panel, black, Chevrolet or GMC, with cutouts for radio panel and knobs, ashtray and heater controls, 17-1/4 inches wide x 10-7/8 inches high with 2-1/2 inch lip on top of dash panel
-W
#237238 07/19/2007 3:11 AM
My dash looked the same way, I had to pull the fan box and a brace under dash to get at crappy Woolworth's speaker under the dash.I figure with the winsheild out, I will be able to weld it up. All those spot welds pretty much garauntee's most dashes are "original to the truck".
I see a GM truck in your future!
