9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible),
243
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,075 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Hey uhh silly question, how many of you are still running the original split rims on your trucks, and those who are not? Are you just running chevy 3/4 ton wheels?
SHould have some pics up by this weekend, I am awiaitng my new carb so I can back her out of the garage, jack her up and tear into the brakes.
Thanks Birge :p | | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | well, i am half and half on my 49 3600. the rear are the 15" split and the front are 16" late model rims that i added clips to for the hub caps. i have since found 2 more 15,s and will place them on the front. the local tire store has no problem mounting these rims.
http://www.flickr.com/photos/11977495@N06/sets/ 1952 COE 1952 3100 1953 3100 1950 6400 1951 Suburban
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I am running them on my 1946 3600. They are 15" 8 lug lock-ring type split rims. I've got 235/75R15 tires on them, and the radial makes it much nicer to drive.
Unless you know EXACTLY what you're doing, I'd take them to a farm implement store and have them mounted there -- or if you've got an industrial tire supplier nearby, they can do it for you too. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I am running 8-lug modern steels off a 91 Chev Suburban. I modified my steering arms and tie-rod for clearance. Large truck tire shops would work on them but they were all different sizes to. 2-15" on front one 16" and one 17" on the rear? These old trucks lead interesting lives over the years. I purchased commercial T/A's for my steel wheels and the are tall and skinny like the originals with modern performance and ease of maintenance. | | | | | Joined: Aug 2005 Posts: 12 New Guy | | New Guy Joined: Aug 2005 Posts: 12 | I'm running new Pacer brand 16" wheels that have a 3.62 inch backspacing. Here is the info. The wheels are by Pacer Wheels. Here is a link: Go to http://www.pacerwheels.com Select RWD and you will see the wheel that is on my truck. Click on it and it will give the detail below and more. Pacer part number is 161M-6781 Wheel size is 16X7 Bolt circle is 8X6.5 Backspacing is 3.62 inches This back spacing clears the steering arms and even leaves enough room for wheel weights when balancing. The tires are radial 235/85 R16. BTW mine is a 3800 but I think the wheel issue is the same as the 3600. Gater | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i am still running 7.00 15 on the 15 in split rims on my 49 3600 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Huh, well I can certainly have someone local put some tires on it for me, I kind of figured the split rims would be a real big problem but I am in a small community so I am sure I can find someone to do it.
Mikes 63 Do you have any pics of your truck when it was a flatbed?
My bed is in pretty rough shape; I need to redo the wood, and then buy two rear fenders, or...make into a flatbed. I have work for a mechanical contractor so getting steel is no problem and welding is no problem, my question was simply how the flat bed connects to the frame. I am sure I will see this once I remove my bed but I was wondering if you had any of these pics to give me an idea.
Thank everyone else for your input
Birge | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I ran the original 17" 3 piece lock ring wheels on my 3800 for several years, and will again if I ever get it back together. Although if I found a set of single wheel 8 lug 19.5" wheels I'd run them with 8R19.5 tires.
Grigg | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Still running the original 15" two-piece rims on my 50 3600. Used 23575R15's on front and two brand-new 7.00-15 bias Power Kings on the back. I love 'em. Of the 5 wheels I broke down 3 myself but did pay a local farm/truck tire shop to dismount the rear ones. After wire brushing and new paint I mounted all replacement tires myself.
Professional Novice
| | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | I'm running the original 1 piece 5.25 x 19.5 inch rims with 8R19.5 tires. | | |
