1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#236929 07/09/2007 10:26 PM
Hey uhh silly question, how many of you are still running the original split rims on your trucks, and those who are not? Are you just running chevy 3/4 ton wheels?
SHould have some pics up by this weekend, I am awiaitng my new carb so I can back her out of the garage, jack her up and tear into the brakes.
Birge :p
Birge
1952 Cheverolet 3600
http://www.flickr.com/photos/bilge77/
#236930 07/09/2007 11:14 PM
well, i am half and half on my 49 3600. the rear are the 15" split and the front are 16" late model rims that i added clips to for the hub caps. i have since found 2 more 15,s and will place them on the front. the local tire store has no problem mounting these rims.
http://www.flickr.com/photos/11977495@N06/sets/
1952 COE
1952 3100
1953 3100
1950 6400
1951 Suburban
#236931 07/10/2007 3:23 AM
I am running them on my 1946 3600. They are 15" 8 lug lock-ring type split rims. I've got 235/75R15 tires on them, and the radial makes it much nicer to drive.
Unless you know EXACTLY what you're doing, I'd take them to a farm implement store and have them mounted there -- or if you've got an industrial tire supplier nearby, they can do it for you too.
#236932 07/10/2007 8:36 PM
I am running 8-lug modern steels off a 91 Chev Suburban. I modified my steering arms and tie-rod for clearance. Large truck tire shops would work on them but they were all different sizes to. 2-15" on front one 16" and one 17" on the rear? These old trucks lead interesting lives over the years. I purchased commercial T/A's for my steel wheels and the are tall and skinny like the originals with modern performance and ease of maintenance.
#236933 07/10/2007 11:03 PM
I'm running new Pacer brand 16" wheels that have a 3.62 inch backspacing. Here is the info.
The wheels are by Pacer Wheels. Here is a link:
Go to http://www.pacerwheels.com
Select RWD and you will see the wheel that is on my truck. Click on it and it will give the detail below and more.
Pacer part number is 161M-6781
Wheel size is 16X7
Bolt circle is 8X6.5
Backspacing is 3.62 inches
This back spacing clears the steering arms and even leaves enough room for wheel weights when balancing.
The tires are radial 235/85 R16.
BTW mine is a 3800 but I think the wheel issue is the same as the 3600.
Gater
#236934 07/10/2007 11:28 PM
i am still running 7.00 15 on the 15 in split rims on my 49 3600
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#236935 07/11/2007 10:14 PM
Huh, well I can certainly have someone local put some tires on it for me, I kind of figured the split rims would be a real big problem but I am in a small community so I am sure I can find someone to do it.
Mikes 63 Do you have any pics of your truck when it was a flatbed?
My bed is in pretty rough shape; I need to redo the wood, and then buy two rear fenders, or...make into a flatbed. I have work for a mechanical contractor so getting steel is no problem and welding is no problem, my question was simply how the flat bed connects to the frame. I am sure I will see this once I remove my bed but I was wondering if you had any of these pics to give me an idea.
Thank everyone else for your input
Birge
Birge
#236936 07/11/2007 11:29 PM
I ran the original 17" 3 piece lock ring wheels on my 3800 for several years, and will again if I ever get it back together. Although if I found a set of single wheel 8 lug 19.5" wheels I'd run them with 8R19.5 tires.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#236937 07/12/2007 6:53 PM
Still running the original 15" two-piece rims on my 50 3600. Used 23575R15's on front and two brand-new 7.00-15 bias Power Kings on the back. I love 'em. Of the 5 wheels I broke down 3 myself but did pay a local farm/truck tire shop to dismount the rear ones. After wire brushing and new paint I mounted all replacement tires myself. smile
Professional Novice
#236938 07/13/2007 1:33 PM
I'm running the original 1 piece 5.25 x 19.5 inch rims with 8R19.5 tires.
