| | | Forums66 Topics128,278 Posts1,058,573 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 19 New Guy | | New Guy Joined: Jan 2007 Posts: 19 | I haven't posted in a while but was wondering if someone out there could give me some ideas on polishing the upper and lower side mouldings on my 1972 C-10. They are all in very good shape as far as dents and dings but are very dirty and dull. I have bought several polishes from the auto parts store but they are still very dull when I am done. I was considering buying a buffing wheel for my bench grinder but really don't know that much about them. Any suggestions? Thanks in advance. | | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | Are they anodized aluminum, or stainless? If theyre stainless,,the best way is to remove them and use a buffing wheel w/buffing compound. If you have to leave them on the truck,,maybe just mask around them and use a buffing wheel on the end of a drill,with the aforementioned buffing compound. If theyre anodized aluminum,,,good luck. | | | | | Joined: Jan 2007 Posts: 19 New Guy | | New Guy Joined: Jan 2007 Posts: 19 | delux54panel, these are the original mouldings on this truck. I would say they are anodized aluminum. I will be removing them from the truck because the truck is going to the paint shop in a couple of weeks. So what ever works best is fine by me. Thanks. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Try #00 steel wool with some aluminum polish. Very labor intensive but does the trick, Scott | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Oven cleaner works on some aluminum parts followed by buffing. Obviously use at own risk as your mileage may vary. | | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | Gotta be careful when theyre anodized aluminum. The anodize is a coating,,so if you break thru that,,you kinda hafta do the whole piece for it to look even. Good Luck, Marty | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I buy metal polish from a guy at the car shows.He sells the waterless car wash and polish.He also sells a metal polish that will shine up just about everything.Check out the car shows and swap meets. | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | The very beat product that I have used is called Autosol. It is absolutely amazing stuff. It is advertised as metal polish/cleaner but it also works on plastic and glass. | | | | | Joined: Apr 2007 Posts: 29 Apprentice | | Apprentice Joined: Apr 2007 Posts: 29 | My wife and I restored a 66 mustang and are now working on a 61 Apache. After seeing what she can do w/steel wool, on windsheild moldings, mirrors, headlight doors. bumpers etc. I'd use nothing else, some compound w/steel wool might be ok but it looks very good without. | | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | I am with the others on the very fine steel wool thing. I used that and Mother's Billet polish on a few things and was very happy with the results.
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | If they are anodixed, the moldings will appear cloudy and will not shine, regardless of what you normally do. These must be re-anodized to get the right shine back. Costs money, but what doesn't?
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | sbw61apache, Could we...uumm....use your wife and steel wool to shine up our trim on our trucks?  | | | | | Joined: Jan 2007 Posts: 19 New Guy | | New Guy Joined: Jan 2007 Posts: 19 | Where would a guy find a place to re-anodize aluminum? | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | I did a search and came up with this, trim restoration. Did a little reading on the home page and it clearly states that the process is very expensive. Good luck. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The problem with aluminum oxide is that it is very hard, just about harder than anything but diamond. Anodizing is just controlled oxidation. If it was originally just polished aluminum, then you have a chance to cut through it with aluminum polish (which is just more Aluminum Oxide). If it was anodized, you will not be able to do it.
To practice, you can work on the bottom of an old Coke can. Its the same stuff with the same problem.
