8 members (Hotrod Lincoln, tclederman, 2-Ton, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom), 167 guests, and 0 robots.
Topics128,089
Posts1,055,988
Members48,430
#235305 06/07/2007 6:45 PM
My truck used to have this ugly white bumper, so we just replaced it with a new repro. Now there is this HUGE gap between the tailgate and the bumper itself. Anyone ever fab up a panel to fill the gap? Surious to see what that would look like. (Match painted to the truck of course).
Thanks guys.
SUPPORT OUR TROOPS
"Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan
1966 Fleetside SWB Webshots
#235306 06/07/2007 6:48 PM
The vedors sell a pair of filler panels for about $40. One 64-66 owner at a show had a nice aluminum panel he had fabbed up.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#235307 06/07/2007 6:52 PM
Sweet. Thanks for the quick response 64!
SUPPORT OUR TROOPS
#235308 06/07/2007 8:17 PM
The factory rock guards look cool and they are painted the body color. They are rolled up on both sides about a 1/4" and have slotted holes in them in two place to allow correct alignment over the rear bumper brace holes. They are a direct bolt-on. I used 1/4" stainless steel carriage bolts, nuts and washers. When installed, they help keep rocks from kicking up between the gap at the bumper and rear cross sill. They are pretty effective and a bit more pleasant than the unsightly looks of the big gap, if they are not there.
Tony
#235309 06/07/2007 8:19 PM
Is this what you are talking about? Mar-K offers them smooth, with a cutout for the license plate, and with a variety of louvers.
#235310 06/08/2007 5:10 AM
TxLaTx thats a roll pan, i think they are talking more about a spash apron of some sort, i may be wrong. i'm not really sure either.
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#235311 06/08/2007 8:20 AM
Not a roll pan or a splash apron. The part is called a rock guard and they were available from the factory. They lay on top of the bumper brackets of the factory bumper that looks like this:
Chrome Rear Bumper With Rock Guards
They are similar on the stepside bed, but they are tapered a little from left to right.
If you look real close at the photo, you can see them on either side near each end of the bumper on top of the bumper brackets.
Tony
#235312 06/08/2007 3:21 PM
I am going to go outside and take a pic of the gap I am talking about. Jeff was thinking he would just fab up a curved panel for it. I think that rock guard is close though.
SUPPORT OUR TROOPS
#235313 06/08/2007 3:40 PM
SUPPORT OUR TROOPS
#235314 06/10/2007 3:12 AM
Lori the gap you took picture of is where factory licnese plate bracket and licnese light assembly is located, it bolts to the two holes you see in the bumper.
jim
#235315 06/10/2007 3:31 AM
Lori:
With the factory rock guards and the factory license plate bracket, there is still some space where you can see through to the ground, but not nearly as much as you have now.
The factory license plate bracket is available from several of the aftermarket truck suppliers, like:
www.lmctruck.com
www.brotherstrucks.com
www.classicparts.com
www.bowtiebits.com
www.oldchevytrucks.com
I have also seen them new on eBay by Boese Engineering. They make a nice place to mount your plate and the bracket comes with a license plate lamp and wiring harness that plugs into your rear tail lamp harness. They run around $35.00.
I hope this helps and good luck with your project.
Tony
#235316 06/10/2007 3:15 PM
I'm going to put a rolled pan on my 63 and cut the slots for the bumper brackets to go through. It will claen up the rear of the bed and give a better looking place to mount the license plate. I'm even going to install license plate lights in it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#235317 06/12/2007 1:06 AM
Socket Breaker
Socket Breaker
Lori66
click on 'links' up at the very top, and then click on 'parts'.
-W
#235318 06/12/2007 1:46 AM
Thanks for the help guys. Soon as I can clear up some more cash I think it will be one of the first things. Ahh the list is neverending.
SUPPORT OUR TROOPS
