| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | My truck used to have this ugly white bumper, so we just replaced it with a new repro. Now there is this HUGE gap between the tailgate and the bumper itself. Anyone ever fab up a panel to fill the gap? Surious to see what that would look like. (Match painted to the truck of course).
Thanks guys.
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The vedors sell a pair of filler panels for about $40. One 64-66 owner at a show had a nice aluminum panel he had fabbed up. | | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | Sweet. Thanks for the quick response 64!
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The factory rock guards look cool and they are painted the body color. They are rolled up on both sides about a 1/4" and have slotted holes in them in two place to allow correct alignment over the rear bumper brace holes. They are a direct bolt-on. I used 1/4" stainless steel carriage bolts, nuts and washers. When installed, they help keep rocks from kicking up between the gap at the bumper and rear cross sill. They are pretty effective and a bit more pleasant than the unsightly looks of the big gap, if they are not there.
Tony | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Is this what you are talking about? Mar-K offers them smooth, with a cutout for the license plate, and with a variety of louvers. Bill | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | TxLaTx thats a roll pan, i think they are talking more about a spash apron of some sort, i may be wrong. i'm not really sure either. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Not a roll pan or a splash apron. The part is called a rock guard and they were available from the factory. They lay on top of the bumper brackets of the factory bumper that looks like this: Chrome Rear Bumper With Rock Guards They are similar on the stepside bed, but they are tapered a little from left to right. If you look real close at the photo, you can see them on either side near each end of the bumper on top of the bumper brackets. Tony | | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | I am going to go outside and take a pic of the gap I am talking about. Jeff was thinking he would just fab up a curved panel for it. I think that rock guard is close though.
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 |
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | Lori the gap you took picture of is where factory licnese plate bracket and licnese light assembly is located, it bolts to the two holes you see in the bumper. jim | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Lori: With the factory rock guards and the factory license plate bracket, there is still some space where you can see through to the ground, but not nearly as much as you have now. The factory license plate bracket is available from several of the aftermarket truck suppliers, like: www.lmctruck.com www.brotherstrucks.com www.classicparts.com www.bowtiebits.com www.oldchevytrucks.com I have also seen them new on eBay by Boese Engineering. They make a nice place to mount your plate and the bracket comes with a license plate lamp and wiring harness that plugs into your rear tail lamp harness. They run around $35.00. I hope this helps and good luck with your project. Tony | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm going to put a rolled pan on my 63 and cut the slots for the bumper brackets to go through. It will claen up the rear of the bed and give a better looking place to mount the license plate. I'm even going to install license plate lights in it, Scott | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Lori66
click on 'links' up at the very top, and then click on 'parts'.
-W | | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | Thanks for the help guys. Soon as I can clear up some more cash I think it will be one of the first things. Ahh the list is neverending.
