2 members (Samantha, klhansen), 308 guests, and 7 robots.
Topics128,162
Posts1,057,042
Members48,460
#234874 05/29/2007 4:05 PM
Apprentice
Apprentice
First of all let me start by saying i loved my truck until i had to change the front brakes out yesterday. Second we ran into a problem and may have solved it wrong but we solved none the less. Our problem was that on the front brake drums they had rivets holding them on is that factory or is it cool that they are no longer there? Just need to know before i am driving down the road and something bad happens. Thanks Justin
1965 Chevy C-10
All Original
Don't worry too much about it. Those rivets are factory, mainly they were for holding the front hub/brearing/drumm assembly together for easier shipping/installation purposes at the factory. Removing them will not hurt a thing.
Bill Burmeister
No need to replace them either.
Unless you want to.
Apprentice
Apprentice
Sweet i thought that but when we started trying to get the drum off i noticed it would not come off past the rivets so i a couple hours later after trying i got mad enough to knock the rivets off.
1965 Chevy C-10
All Original
Riding in the Passing Lane
It,s best to take them off. They interfear with some custom wheels.
1972 Chevy c10 Cheyenne Super
duckhunter65:
The factory drums should slide off and on the hubs with no obstructions. You should be good to go.
Tony
Apprentice
Apprentice
Thanks to all of the comments. I was kinda worried when i did it but now that yall say it is ok i know to do that to the other side when i get my other brake line in.
1965 Chevy C-10
All Original
Most people pull hubs and all.
last summer I changed the shoes, lines, wheel cylinders, and the master cylinder. "man was that a messy job" :blat:
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
The only time I've cut the rivets off a front drum is when the drums needed to be replaced. Just take the spindle nut off, and slide hub, drum and all off the spindle. It's easier and more accurate to machine the drums using the bearing races as centering points, too.
#234884 05/31/2007 11:30 PM
Yeah, in the house my least favorite - plumbing. In the garage - brakes! Both are worth doing well. grin
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
