| | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I recently ordered armrests for my '56 from Classic Parts of America. They are imported by Counterpoint Automotive and I imagine all the rest of the vendors sell the same ones. There was a problem with the template provided. I sent Classic Parts an Email detailing the problem: Dear Customer Service,
I recently ordered 2 armrests, #19-631. These come with a template for drilling holes in the door panel. The hole spacing on the template is wrong. The aft hole is correctly placed, 7⅛" from the aft edge of the panel. However the forward hole is shown 5½" from the aft hole. The holes in the armrest are 6" apart. I discovered this after drilling my first panel. I had to elongate the forward hole to install the armrest.
There's really no harm done as the armrest covers the hole but it is frustrating to have to remove the panel again to elongate the hole. You really should provide correct templates. If any of you order armrests be sure to correct your template before drilling. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Wow Cletus... I bet that wasn't the first draft of your letter!  | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Cletis is so diplomatic.  | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | more of that great aftermarket quality. It seems this is the case more often than not when trying to buy aftermarket parts.
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Those folks in China really don't care whether they fit or not, they just make 'em. Prolly an issue somewhere in translation, or maybe even on purpose like the tainted pet food. | | | | | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | I am having a similar problem with the drivers side window regulator. I couldnt get it to line up with the holes in the door so I pulled it back out and measured. The regulator is a full 1/2 inch shorter than the old one! I called Classic parts and Angel informed me that I was the second person with this problem. She was really nice and is sending UPS out to pick it up today. I told her that I want the replacement measured before it is shipped out. Its bad enough to have to pull out the window assembly in first place but then to have this frustration as well. I wouldn't buy any window regulators from them for awhile til they get this one fixed. I will let you know how it turns out. If they dont have the right one I will go to LMC truck. Five bucks cheaper! | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | sure dont sound like the Cletis I know.....  now let me tell you what he probably said.........on second thought, I better not... I am with you though cletis,, when a hole dont line up it sure can create a problem.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I ordered armrests for my '54 from Classic Parts ... I didn't use their template, I made my own from the door itself, but the problem I had was with the plastic parts of the armrests. I slammed the door one cold Winter day and the armrest came off in my hand! The cold (thin, cheapo) plastic broke! I thought the plastic looked pretty hefty at first ... but after it broke and I looked at it, it was *really* thin! I wound up fabricating my own parts from red oak and covered everything in elk leather. I'm much happier now. You can see what I did Here PS - I dunno about the armrests for a '56 but the armrests for a '54 "hang" when they're mounted! You can see the details about this on my page (linked above) ... they make the armrests for a 90-degree angle but the door on a '54 is angled where the armrests mount, so you wind up with a tilted armrest! I fixed that problem as well.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I GUESS I am with Alan on this one ...i was thinkin on orderin a set as mine has NONE (custom interior) ...I guess Ill just build my own outta Hickory from work ..an say NO to the China Man @#$%$ !!!!!!!!! | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hickory sounds pretty sweet to me, man! Plus, you can make them any shape and size you want.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Nothing beats a good piece of hickory. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | well when Peggy gets my update in you will see the hickory dash insert i made for my gauges , My dash was cut up bye my Unc. i got he truck from he wanted to install LED gauges but never did ...so i had a big square molded in hole to fill ...it came out pretty sweet ! | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I'm looking forward to seeing that! I just covered my Dolphin dash inserts for the gauges with elk: See Here I can't wait to get my truck back with its new paint and install these!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | the Elk covering looks Great ! | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Thanks! I'm real happy with it, too. My truck will be back with a new paint job late Summer and then I'll be doing the whole interior in elk -- hot dog!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I made mine out of 3x3x1/2" guaranteed not to break. | | |
