5 members (J Lucas, Brian Moore, Pete1946, Otto Skorzeny, Hotrod Lincoln), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#233519 05/08/2007 5:23 AM
I recently ordered armrests for my '56 from Classic Parts of America. They are imported by Counterpoint Automotive and I imagine all the rest of the vendors sell the same ones. There was a problem with the template provided.
I sent Classic Parts an Email detailing the problem:
Quote
Dear Customer Service,
I recently ordered 2 armrests, #19-631. These come with a template for drilling holes in the door panel. The hole spacing on the template is wrong. The aft hole is correctly placed, 7⅛" from the aft edge of the panel. However the forward hole is shown 5½" from the aft hole. The holes in the armrest are 6" apart. I discovered this after drilling my first panel. I had to elongate the forward hole to install the armrest.
There's really no harm done as the armrest covers the hole but it is frustrating to have to remove the panel again to elongate the hole. You really should provide correct templates.
If any of you order armrests be sure to correct your template before drilling.
#233520 05/08/2007 7:32 AM
Wow Cletus... I bet that wasn't the first draft of your letter! grin
#233521 05/08/2007 1:33 PM
Cletis is so diplomatic. wink
#233522 05/08/2007 1:44 PM
more of that great aftermarket quality. It seems this is the case more often than not when trying to buy aftermarket parts.
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
#233523 05/08/2007 1:51 PM
Those folks in China really don't care whether they fit or not, they just make 'em. Prolly an issue somewhere in translation, or maybe even on purpose like the tainted pet food.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#233524 05/08/2007 7:23 PM
I am having a similar problem with the drivers side window regulator. I couldnt get it to line up with the holes in the door so I pulled it back out and measured. The regulator is a full 1/2 inch shorter than the old one! I called Classic parts and Angel informed me that I was the second person with this problem. She was really nice and is sending UPS out to pick it up today. I told her that I want the replacement measured before it is shipped out. Its bad enough to have to pull out the window assembly in first place but then to have this frustration as well. I wouldn't buy any window regulators from them for awhile til they get this one fixed. I will let you know how it turns out. If they dont have the right one I will go to LMC truck. Five bucks cheaper!
#233525 05/08/2007 8:10 PM
sure dont sound like the Cletis I know..... grin now let me tell you what he probably said.........on second thought, I better not...
I am with you though cletis,, when a hole dont line up it sure can create a problem..
Redryder pix
My Hotrod
#233526 05/08/2007 11:14 PM
I ordered armrests for my '54 from Classic Parts ... I didn't use their template, I made my own from the door itself, but the problem I had was with the plastic parts of the armrests. I slammed the door one cold Winter day and the armrest came off in my hand! The cold (thin, cheapo) plastic broke!
I thought the plastic looked pretty hefty at first ... but after it broke and I looked at it, it was *really* thin!
I wound up fabricating my own parts from red oak and covered everything in elk leather.
grin
I'm much happier now.
You can see what I did Here
PS - I dunno about the armrests for a '56 but the armrests for a '54 "hang" when they're mounted! You can see the details about this on my page (linked above) ... they make the armrests for a 90-degree angle but the door on a '54 is angled where the armrests mount, so you wind up with a tilted armrest! I fixed that problem as well.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#233527 05/09/2007 2:02 PM
I GUESS I am with Alan on this one ...i was thinkin on orderin a set as mine has NONE (custom interior) ...I guess Ill just build my own outta Hickory from work ..an say NO to the China Man @#$%$ !!!!!!!!!
1952 Chevy Shortbed
Photos in Photobucket
#233528 05/09/2007 2:06 PM
Hickory sounds pretty sweet to me, man! Plus, you can make them any shape and size you want.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#233529 05/09/2007 4:02 PM
Nothing beats a good piece of hickory.
#233530 05/09/2007 5:04 PM
#233531 05/10/2007 1:33 PM
well when Peggy gets my update in you will see the hickory dash insert i made for my gauges , My dash was cut up bye my Unc. i got he truck from he wanted to install LED gauges but never did ...so i had a big square molded in hole to fill ...it came out pretty sweet !
1952 Chevy Shortbed
#233532 05/10/2007 1:41 PM
I'm looking forward to seeing that!
I just covered my Dolphin dash inserts for the gauges with elk:
See Here
I can't wait to get my truck back with its new paint and install these!
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#233533 05/10/2007 1:59 PM
the Elk covering looks Great !
1952 Chevy Shortbed
#233534 05/10/2007 2:06 PM
Thanks! I'm real happy with it, too. My truck will be back with a new paint job late Summer and then I'll be doing the whole interior in elk -- hot dog!
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#233535 05/11/2007 1:43 AM
I made mine out of 3x3x1/2" guaranteed not to break.
