0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
Junior Member
Junior Member
Hello,
I was wondering if anyone could give me some tips on how to install my windshield into my 53 chevy 5 window pickup. I installed the corner glass and the rear glass, which wasn't so bad once I figured out that soap makes the work a lot easier! Any tips would be greatly apprectiated!
What nation always wins? DETERMInation!
Junior Member
Junior Member
Thanks man, you rule!
i put a little string in the rubber grove, and someone pulls string slowly, as somebody else lightly pushes on the glassit sets pretty easy that way
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
What about sealing the windsheild/back window once they are installed? Is that necessary or does the rubber gasket do the job well enough?
mine for the most part did well by itself, unless we get an ungodly down pour then the lower outside corners seep a little
1964 gmc 4000
1973 gmc 6000
1994 chevy 1500
Junior Member
Junior Member
I read in an article that you have to take your windshield to a glass shop to get sealed.
I paid a guy to come and seal up my windshield and rear window ... they both had leaks when I first got my truck.
It cost me $80 to learn that all I needed to do (myself) was to squirt some clear silicone caulk under the rubber!
DUH!
:hammering:
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Thanks Alan-
The instructions posted on intalling the glass says to take it to a glass shop for sealing and I figured it would be something easy that I could do myself!
Did you use any particular kind of clear silicone or just whatever type you find at the hardware store that is clear, like clear silicone bathtub caulk?
Read somewhere that the repro rubber is not as thick as the original and that could cause leaks. I know mine leaks at the bottom corners during a heavy rain.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Quote
Originally posted by NM51:
Thanks Alan-
Get the clear "Window & Door" silicone (for outdoor use).
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
Have I missed it or can you order glass from OEM vendors? I won't be needing glass for a few months but it's always good to have options.
~Jim
you can order glass from vendors but I have found that the local shops can cut the FLAT glass if you have the old glass to go by and save $$$.
I bought a '59 windshield locally.
