0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 3 Junior Member | | Junior Member Joined: Apr 2007 Posts: 3 | Hello, I was wondering if anyone could give me some tips on how to install my windshield into my 53 chevy 5 window pickup. I installed the corner glass and the rear glass, which wasn't so bad once I figured out that soap makes the work a lot easier! Any tips would be greatly apprectiated!
What nation always wins? DETERMInation!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Apr 2007 Posts: 3 Junior Member | | Junior Member Joined: Apr 2007 Posts: 3 |
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i put a little string in the rubber grove, and someone pulls string slowly, as somebody else lightly pushes on the glassit sets pretty easy that way 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | What about sealing the windsheild/back window once they are installed? Is that necessary or does the rubber gasket do the job well enough?
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | mine for the most part did well by itself, unless we get an ungodly down pour then the lower outside corners seep a little 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Apr 2007 Posts: 3 Junior Member | | Junior Member Joined: Apr 2007 Posts: 3 | I read in an article that you have to take your windshield to a glass shop to get sealed.
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I paid a guy to come and seal up my windshield and rear window ... they both had leaks when I first got my truck.
It cost me $80 to learn that all I needed to do (myself) was to squirt some clear silicone caulk under the rubber!
DUH! :hammering:
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Thanks Alan-
The instructions posted on intalling the glass says to take it to a glass shop for sealing and I figured it would be something easy that I could do myself!
Did you use any particular kind of clear silicone or just whatever type you find at the hardware store that is clear, like clear silicone bathtub caulk?
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Read somewhere that the repro rubber is not as thick as the original and that could cause leaks. I know mine leaks at the bottom corners during a heavy rain. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Originally posted by NM51: Thanks Alan-
Did you use any particular kind of clear silicone or just whatever type you find at the hardware store that is clear, like clear silicone bathtub caulk? Get the clear "Window & Door" silicone (for outdoor use).
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Have I missed it or can you order glass from OEM vendors? I won't be needing glass for a few months but it's always good to have options.
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | you can order glass from vendors but I have found that the local shops can cut the FLAT glass if you have the old glass to go by and save $$$. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I bought a '59 windshield locally. | | |
