| | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Paws51 got me to thinking. I need a little help from some of you experts. Can you tell a '53 from a '48? How? I'm going to have some fun with a friend that has a '53 that's going to pass it off as a '48 to get into a pre '49 show. Thanks
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Easiest way to tell is that the 53 has vent windows in the doors. 48 did not have em. | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Also 51 is the last year for drop down door handles.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | 48 also had gas tank in the bed, not in the cab as 49-53 did, so you have no filler neck on the cab for a 48 you have a filler neck on the 53, a 53 also has no side vent, a 48 does 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | 48- one pc. windows in the doors 53 has the vent window. 48 has 9 boards in the box 53 has 8 boards. 48 has the vent in the drivers side of the cab infront of the door 53 does not 48 speedo is different then the 53 48- the door seal that is attached to the cab is held in with trim that is screwed on 53 the door seal is held on with a channel strip that is spot welded onto the cab 48- drop down door handles 53- push button door handles | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 48 hood side chrome emblem states THRIFTMASTER or LOADMASTER (no CHEVROLET and no series designation); 53 hood side emblem changed this year and looks like the 54 emblem (series-number designation but no CHEVROLET)
tube-style shocks in 53; knee-action shocks in 48
bendix brakes in 53; huck brakes in 48
door windlace attached with metal screw-in strips in 48; windlace held in by slide-in channels in 53
outer grill bars painted body color and inner grill bars painted Thistle (light) gray in 53 (no stripes on the bars); inner and outer grill bars painted body color in 48 - outer bar had a horizontal stripe matching the cab stripe
chrome grill was available in 48; no chrome grill option in 53
headliner middle-bar was a screw-in metal strip in 48; floating metal strip in 53
front hood emblem die cast in 48; stainless steel in 53
80 mph speedometer in 48; 90 mph in 53
Door post ID plate blue & silver in '53; black & silver in 48 | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | between 52motorhead and tclederman you should your answser on the differences beltfed, i know the 48 hood had chevy on the side, i think it had thriftmaster also 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Thanks a ton guys. You continue to amaze me as to your knowledge of this old trucks. I think 52motorhead and tclederman mothers used an old stovebolt for their crib. I afraid to ask what their mothers used as a pacifier. Thanks
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Here is just a few more things I could think of 1948 fule tank was under the bed 1953 in the cab 1948 left hand side vent on cowl 1953 wing vents (as stated before) 1948 speedo went to 80 mph 1953 speedo went to 90 mph 1948 temp gauge went to 212 deg 1953 temp went to 220 deg 1948 needles were red (Chevy 1953 needles were white (Chevy) 1948 radio the back cover was slanted 1953 radio the back cover was stright 1948 stock could have chrome hubcaps, bumper and/or grill 1953 would of been painted 1948 window crank knobs and wiper knob on dash would of been crome with stainless trim over radio speaker grill with stainless glove box 1953 window crank knobs and wiper knob on dash with would of been maroon nonmetal and painted upper & lower trim on speaker grill along with glove box door | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Your friend will have a major job passing a 53 off as a 48. Should be interesting...
~Jim
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | How about you guys list all the "visual" differences of "all" the advance design series. | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | How about the fire wall changes from '49 to the '50 model year. Flat in '49, support rib bends beginning in '50. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | all true unless someone has a 48 and then interchange some parts..........some have been known to do that,,,,,,,,,,,,,,just check the title , that way you might know for sure if it is in the right class, some have been known to fib on that deal too. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Originally posted by Builder: How about you guys list all the "visual" differences of "all" the advance design series. You know I'm just about sick enough with this bug I have thought about it. It would be great to have a page where we all could add and discus corrections on these kinds of things but keep a running live account. I am not the only one? It's nice to know I have family here. Mike | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I am working on a compilation of information from various sites. The rough outline is on this page. At the bottom of that page are links to sites that have posted information about various years. Here is a draft of the first page | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I think that the idea helping someone modify a vehicle to participate in an inappropriate class sucks. It is grossly unfair to those who particpate legitimately. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | ya i do have to agree with Baldy, plus there are to many differences that i don't think it would be worth it 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'm going to have some fun with a friend that has a '53 that's going to pass it off as a '48 to get into a pre '49 show. I think that the idea helping someone modify a vehicle to participate in an inappropriate class sucks. It is grossly unfair to those who particpate legitimately. Agreed. Who is helping whom to do what? | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You are correct, TC. Maybe the fun he intends to have is to rag on the friend. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | 1951 and before had drop handles Also 51 is the last year for drop down door handles. 51 was the only year for drop handles and vent windows. first part of 51 the bed had 9 boards mid to late 51 they went to 8 boards.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Believe me guys, I am not and will not help him modify his truck for that purpose. I will help him if he is broken down. I, with "tongue in cheek", am trying in a friendly way to sway him to be legit. That's why I needed to know the differences. Thanks for your help.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | Originally posted by beltfed: I think 52motorhead and tclederman mothers used an old stovebolt for their crib. I afraid to ask what their mothers used as a pacifier. Thanks spark plugs  | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | "re·store Pronunciation: ri-'stOr, Etymology: Middle Eng, from Latin restaurare to renew,rebuild 1 :GIVE BACK,RETURN 2 :to bring back to or put back into a former or original state:RENEW Now is that what you did with a V8 and air bags ?" OLtrucks-I love this!! One of my pet peeves is people who modify the Heck out of a vehicle,then consider it to be "restored" Speed | | | | | | Anonymous Unregistered | | Anonymous Unregistered | speed 6351 Thanks I guess you can see what I think here thats why I love this site and enjoy dang near everyone that comes to it, Just call e'm what they are and that way I'll know to walk on by or not. he he he
Mike | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I passed my 53 off as a 48. Chances are pretty good no one at the show would really know the difference. If someone asked, I just told them I swapped doors cause I liked the vents and push button handles. | | |
