1 members (51sub),
128
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | So I totally dig how my truck is looking these days. I like the multi-paint patina looks (if you want to see what I mean check the gallery link in my signature), but I have a problem. I am worried about some of the surface rust that is starting to show through the primer. Is there some sort of oil I could rub my truck down with and keep it looking like it does now without getting worse?
I was thinking about just rubbing the whole truck down in WD-40? I want a little bit of protection for the metal that is there. Ideas? I just want a simple solution that will help preserve the metal.
Thanks in advance.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I knew a guy in Austin, Texas that had the same situation and rubbed his car with 30 wt oil. Gave him the look he liked.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | WD40 is water based and will not last long. Johnson's past wax. | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | I dig how your truck looks too.
How about 3 in 1 oil... rubbed on by a rag.
Edit by me...
Use diesel fuel.
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Aug 2006 Posts: 18 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 18 | I have had your same situation and was told by an oldtimer to wipe it down with transmission fluid. The fluid will not harm rubber/neoprene seals, gaskets and such. It works for me, but over time it will collect dust, but not as bad as you might think. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Patina isn't supposed to be shiny!
Bill Burmeister | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Au contaire, 55!!! I've got a '71 Dodge D-100 PU that has the original orange paint with very small places where the factory primer is showing through. You can make patina "shine" real nice by taking 000 steel wool to it, then using tranny fluid over it. The wool smoothes the old paint out and removes the oxidation, while the tranny fluid makes the shine, shine more!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Just wash the dirt off it once and a while and put a sticker on it that says......"It is Painted". | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | I knew a guy once that sprayed diesel on his truck about twice a year, all over. He'd wipe the body down with a rag to get rid of the excess. He even sprayed the underside, never had any rust problems the whole time he had that truck and it was a mid 70's F**d. | | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | I use Meguiar's Quik Detailer on my rough Rustoleum paint job. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | As a kid I had a 1946 Jeep Wagon, you might remember, the ones with the brownish paint and the lighter beige....sorta "faux woodie" panels.
The 15 year old enamel was pretty dead and one of the body shop guys, who did some work for a local used car lot, suggested I add 1 cup of kerosene to a bucket of wash water. You had to towel dry the paint to avoid water spots but that ole Jeep looked like it had a fresh paint job for at least a week. Driving on a dirt road would require a quick "dust-off"...too bad they didn't have the "California Dusters we have today.
It works especially good on a dead red paint job! Doesn't cost much, is easier than a wax job which will be rough to buff out, and the diluted mixture wasn't that rough on the rubber seals.
BTW....you get better results if you have the water (no soap) in the bucket warm. Give it a try.....you'll be pleasantly surprised.
Dave | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | wash it good and shoot it with clear coat | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I use matte finish clear coat | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | I've never tried this but what about trying one of those rust stopper products in the spray can like Permatex makes or some such? You could try in inside the bed or something just to see how much it changes the "patina". | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I think you would ruin any patina by putting a clear coat on it. What is the point of painting patina? Isn't the beauty of the patina the ageing of the surface? Shine what is there if you have to but to clear coat it doesn't make sense to me. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | Patina is natural, you arent supposed to protect it, or any of that... just let it be..
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | These stovebolts will outlast us all anyway. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would avoid putting anything on the body that might affect a future paint job. Anything that's soaked into the paint and body could lift on a fresh paint job, Scott | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Wow! Thanks a lot everyone. I am not looking to clear coat it, but I would like to protect the spots where I have almost bare metal showing. I don't want to ruin the patina, I just want a little peace of mind as far as rust and stuff. Thanks for all of the ideas and stuff. Anyone else?
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Originally posted by 48bigtrucks: I would avoid putting anything on the body that might affect a future paint job. Anything that's soaked into the paint and body could lift on a fresh paint job, Scott Very good point Scott.
| | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | In Arizona we typically clear seal copper once it has been acid washed to the desired patina. The problem is with so little rain, that is the only way to get it to the color you want. We do this on custom garage doors and fascia boards all the time.
Granted, if you wanted to repaint in the future, it would off course have to all come off and of I course I wouldn't recommend acid washing a steel truck! | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | I used rust converter on my 49,the brand name is Klean-Strip.It turns rust to black primer.I think I bought it at Walmart. ------------------ Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Not a bad looking truck. If it were mine I would just leave it alone, besides patina will grow on you just think how good looking the old Chev will be in another ten years. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Diesel, kerosene, tranny fluid, W-D 40, Hum... And some of you guys were concerned about the gasoline smell in the cab... My wife would kill me.
~Jim
