6 members (Peggy M, cmayna, baldeagle, JW51, fonz8261, obs2kl), 56 guests, and 5 robots.
Topics128,021
Posts1,055,346
Members48,420
#226892 02/11/2007 10:25 PM
Hey Folks,
Trying to remove some of the bracketry off my '53's frame. I was certain it was discussed here before, but can't seem to find anything on removing them.
I've tried grinding the heads and pounding them out. I've tried cutting the head off with a cutting torch and knocking it out when its hot, but that doesn't seem to be working either.
So whats the best way to get them out?
Or do I just have to hit harder?
Colin
#226893 02/11/2007 10:51 PM
Riding in the Passing Lane
I always use a cutting torch. Wack the head off & then blast into the center of the rivet. It,s best to let it cool a little or you just swell it up some more. You can drill a hole in the center & grind or chisel the head off.
1972 Chevy c10 Cheyenne Super
#226894 02/11/2007 10:57 PM
Impressive, aren't they?!
With so much literally falling off my ol rig, the only stuff that I needed to remove and it takes an act of g_d to get it to break its grip ;'}
Unfortunately, all I could figure to do is to proceed as you describe (and I can show you the scars on my hands to prove it)
Good luck!
Everything is different now...
#226895 02/11/2007 11:00 PM
Ex Hall Monitor
Ex Hall Monitor
I've seen an air chisel used. Wear ear plugs. grin
#226896 02/11/2007 11:26 PM
1 Offline
I Just got done removing a bunch of them to make way for a IFS kit and used a air chisel Its like Tiny said WEAR EAR PLUGS but it cuts thru them like butter. I had several of them out in minutes
Good Luck
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
#226897 02/11/2007 11:28 PM
Chisel the heads off, drill a hole through them and punch them out.
Or just chisel/grind off the heads, knock off the attached piece and grind it smooth.... that way you dont have a hole in your frame.
Another quality post.
Real Trucks Rattle
#226898 02/12/2007 12:10 AM
Wearing myself out I've tried it all from torch to chisel and can tell you the easiest way to get those big stove bolts out is to get yourself a grinder, a large punch and a sledge hammer; grind the head off and a couple of hits on the punch and she will shoot out like a rocket. Good luck.
~Jim
#226899 02/12/2007 1:11 AM
air impact with a punch head.grind the heads flat to the frame or torch them off at head
dan-pa
#226900 02/12/2007 2:00 AM
Ditto on the air chisel to cut the heads...then I ground one of the air chisel pointed tools off flat to make an air powered drift punch...they popped right out. No air chisel.....grind, drill and then the big hammer.
Air chisel can get in where you don't have enough room to grind the head. Replace with bolts and save the next guy some agony!!
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#226901 02/12/2007 2:48 AM
i say air chisel an i dont wear ear plugs an it is showing i failed my last 2 hearing test so i would advise it
LEWIS
#226902 02/12/2007 3:31 AM
whats that you say, speak up so I can hear you :hammering:
#226903 02/12/2007 3:36 AM
Center punch the head then drill through it with a drill the approximate size of the rivet shank. Stick a punch in the hole and knock the rivet out.
#226904 02/12/2007 3:51 AM
i've used a chisel, and about a 2 pound hammer and smack the heck out of them it works but is a little work, and dangerous-don't missed the chisel or you'll wish you hadn't. i did it on my 49 3600 removing step brackets
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#226905 02/12/2007 4:59 AM
I spent four hours today removing rivets and rusted bolts from a frame. I sometimes vary my technique a little because it gets boring sometimes.
My favorite approach is to cut an 'x' in the head, chisel the head off, and then hit the rivet with a punch to drive it out.
If that doesn't work I will drill the rivet and hit it again.
The same approach usually works for rusted boths too.
I don't like using a torch because I often end up cutting things I didn't want to that way.
#226906 02/12/2007 5:23 AM
Colin,
I ground off the heads of the rivets, then fired up a cutting torch and cut out the center of the rivets. I waited until they cooled, then pounded out the rivets with a punch and large hammer.
If you look at the frame of the '59 I gave you, you can see where I removed the cab mount brackets this way.
Have fun, it's not really that hard.
#226907 02/12/2007 6:00 AM
Thanks for all the tips guys!
After I edited the 'maybe i'm not hitting them hard enough', I went back out and tried just that. Put a punch in a vice grip and went at 'er.
I think i'm going to try using the torch aswell as Photo suggested.
Thanks again!
#226908 02/12/2007 7:51 AM
The easiest I have found lately is drill the center with an 1/8" bit. Then a bit somewhere between a 1/8" bit and a 3/8" bit. Then a 3/8" bit. Sometimes I go from 1/8" to 3/8". Both heads fall right off. And no smashed thumbs!! No distorted metal!! No gouges!!!!
#226909 02/12/2007 12:23 PM
After I struggled with mine, I discovered why some of them were so brutal to get out. Sometimes the holes of the attached pieces were not exactly the same size and sometimes they were not perfectly aligned, when assembled at the factory. The result was that the hot rivet just morphed to the various shapes of the void and thus they didn't want to just slide out. I also had one head fracture in shear, just like a piece of cast iron. I think the hardness varies from rivet to rivet.
1951 1 Ton Completed
#226910 02/12/2007 9:29 PM
Quote
That's why they use rivets in the first place- they work a lot better than bolts in that application. They fill the hole they are put in.
Paint & Body Shop moderator
#226911 02/12/2007 9:33 PM
I have ground the rivet heads off,then used a good sized punch and hammer.It takes several blows with the hammer,rivet then shoots out like a bullet.Wear safety glasses always.
1951 3100 Chevrolet
#226912 02/13/2007 4:43 AM
I agree Bowtie, I can grind a rivet head in about 25 seconds then using a large (15") punch hit it about 2 or 3 good licks with a 4 lb sledge hammer and out she goes. It took me 3'4 of the frame and using a lot of techniques before I figured it out.
~Jim
#226913 02/13/2007 8:03 AM
Out of desperation, I used my 18v recip saw with a good bi-metal saw blade. I was surprised how easily the heads cut off. I then knocked out the remainder with a center punch and a two pound hammer. It worked great.
Good luck with your project.
Tony
#226914 02/13/2007 1:30 PM
as 4onthefloor said, that is exactly why rivets were used. It is interesting that they helped make up for the inaccuracies of the mass production setup. It must have been a very noisy environment where the riveting was going on.
#226915 02/13/2007 2:49 PM
Blue tip wrench is the only way to go,,IMO. I have hit my hands too many times w/hammers. I use a very small tip cutting torch, off the head then melt out the center. For salvage yard work I use an easy to carry small plumbers torch setup. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#226916 02/14/2007 2:52 PM
i thought they were pretty easy to remove.my method is to drill through the head with a sharp bit. slice off the head with a sharp chiesel then knock out with a punch.........dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
#226917 02/14/2007 6:00 PM
A word of caution.
A couple of months back I drilled off the heads and punched out the remaining bodies of the several rivets holding the rear cross member to the frame on my '41. At this point I should mention that the crossmember had a 4" bow pulled into it. This was probably a result of being pulled out of the mud by some really big truck, tractor, or dozer. So when the last rivet on one side was driven out it SHOT all the way across the garage and put a very nice river shaped hole in my drywall.
Lesson here....The rivets do fill the hole and there is no room for movement when the parts being held together are pulled or pushed out of the original alignment. When the rivet lets go something is going to move very quickly.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#226918 02/14/2007 6:39 PM
I think they are easy too.
I use a cold chisel that is about 14" long and 1" wide with a good sized cross peen hammer on a 18" handle. Holding the chisel with vice grips allows you to really swing the hammer without worry. Usually only 3 or 4 blows is needed for a 3/8" rivet. Then follow with a punch.
An air hammer with chisel and punch is really nice if you have one and air is available.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#226919 02/14/2007 7:15 PM
I think an air chisel would make things a lot easier. I found that some rivets were harder to remove than others. I actually bent a brace pounding the rivet out.
#226920 02/14/2007 7:43 PM
6 heaven
6 heaven
When drilling the rivets(any rivet in general) try not drilling all the way through the rivet, maybe halfway or so. This will leave an indentation or pocket for your punch to fit in, while weakening the fit of the rivet. The punch will stay in the drilled hole when hitting!
#226921 02/15/2007 2:24 AM
When removing rivets, don't be afraid to drill through the shank when you have one that doesn't want to punch out. If you are going to put a bolt in the hole, you will need to drill to the bolt size anyhow, rivet hole sizes are not the same as bolt sizes.
Fred
52 3600
69 C-10
