| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Hey Folks,
Trying to remove some of the bracketry off my '53's frame. I was certain it was discussed here before, but can't seem to find anything on removing them. I've tried grinding the heads and pounding them out. I've tried cutting the head off with a cutting torch and knocking it out when its hot, but that doesn't seem to be working either.
So whats the best way to get them out? Or do I just have to hit harder?
Thanks Colin | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I always use a cutting torch. Wack the head off & then blast into the center of the rivet. It,s best to let it cool a little or you just swell it up some more. You can drill a hole in the center & grind or chisel the head off. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 113 | Impressive, aren't they?!
With so much literally falling off my ol rig, the only stuff that I needed to remove and it takes an act of g_d to get it to break its grip ;'}
Unfortunately, all I could figure to do is to proceed as you describe (and I can show you the scars on my hands to prove it)
Good luck!
Everything is different now...
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've seen an air chisel used. Wear ear plugs.
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I Just got done removing a bunch of them to make way for a IFS kit and used a air chisel Its like Tiny said WEAR EAR PLUGS but it cuts thru them like butter. I had several of them out in minutes Good Luck Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Dec 2002 Posts: 3,438 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,438 | Chisel the heads off, drill a hole through them and punch them out.
Or just chisel/grind off the heads, knock off the attached piece and grind it smooth.... that way you dont have a hole in your frame.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Wearing myself out I've tried it all from torch to chisel and can tell you the easiest way to get those big stove bolts out is to get yourself a grinder, a large punch and a sledge hammer; grind the head off and a couple of hits on the punch and she will shoot out like a rocket. Good luck.
~Jim
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | air impact with a punch head.grind the heads flat to the frame or torch them off at head
dan-pa
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Ditto on the air chisel to cut the heads...then I ground one of the air chisel pointed tools off flat to make an air powered drift punch...they popped right out. No air chisel.....grind, drill and then the big hammer.
Air chisel can get in where you don't have enough room to grind the head. Replace with bolts and save the next guy some agony!! | | | | | Joined: Jan 2007 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 116 | i say air chisel an i dont wear ear plugs an it is showing i failed my last 2 hearing test so i would advise it
LEWIS
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | whats that you say, speak up so I can hear you :hammering: | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Center punch the head then drill through it with a drill the approximate size of the rivet shank. Stick a punch in the hole and knock the rivet out. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i've used a chisel, and about a 2 pound hammer and smack the heck out of them it works but is a little work, and dangerous-don't missed the chisel or you'll wish you hadn't. i did it on my 49 3600 removing step brackets 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I spent four hours today removing rivets and rusted bolts from a frame. I sometimes vary my technique a little because it gets boring sometimes.
My favorite approach is to cut an 'x' in the head, chisel the head off, and then hit the rivet with a punch to drive it out.
If that doesn't work I will drill the rivet and hit it again.
The same approach usually works for rusted boths too.
I don't like using a torch because I often end up cutting things I didn't want to that way.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Colin,
I ground off the heads of the rivets, then fired up a cutting torch and cut out the center of the rivets. I waited until they cooled, then pounded out the rivets with a punch and large hammer.
If you look at the frame of the '59 I gave you, you can see where I removed the cab mount brackets this way.
Have fun, it's not really that hard.
Photo | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thanks for all the tips guys!
After I edited the 'maybe i'm not hitting them hard enough', I went back out and tried just that. Put a punch in a vice grip and went at 'er.
I think i'm going to try using the torch aswell as Photo suggested.
Thanks again! | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | The easiest I have found lately is drill the center with an 1/8" bit. Then a bit somewhere between a 1/8" bit and a 3/8" bit. Then a 3/8" bit. Sometimes I go from 1/8" to 3/8". Both heads fall right off. And no smashed thumbs!! No distorted metal!! No gouges!!!! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | After I struggled with mine, I discovered why some of them were so brutal to get out. Sometimes the holes of the attached pieces were not exactly the same size and sometimes they were not perfectly aligned, when assembled at the factory. The result was that the hot rivet just morphed to the various shapes of the void and thus they didn't want to just slide out. I also had one head fracture in shear, just like a piece of cast iron. I think the hardness varies from rivet to rivet. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Originally posted by truckernix: After I struggled with mine, I discovered why some of them were so brutal to get out. Sometimes the holes of the attached pieces were not exactly the same size and sometimes they were not perfectly aligned, when assembled at the factory. The result was that the hot rivet just morphed to the various shapes of the void and thus they didn't want to just slide out. I also had one head fracture in shear, just like a piece of cast iron. I think the hardness varies from rivet to rivet. That's why they use rivets in the first place- they work a lot better than bolts in that application. They fill the hole they are put in.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I have ground the rivet heads off,then used a good sized punch and hammer.It takes several blows with the hammer,rivet then shoots out like a bullet.Wear safety glasses always. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I agree Bowtie, I can grind a rivet head in about 25 seconds then using a large (15") punch hit it about 2 or 3 good licks with a 4 lb sledge hammer and out she goes. It took me 3'4 of the frame and using a lot of techniques before I figured it out.
~Jim
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Out of desperation, I used my 18v recip saw with a good bi-metal saw blade. I was surprised how easily the heads cut off. I then knocked out the remainder with a center punch and a two pound hammer. It worked great.
Good luck with your project.
Tony | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | as 4onthefloor said, that is exactly why rivets were used. It is interesting that they helped make up for the inaccuracies of the mass production setup. It must have been a very noisy environment where the riveting was going on. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Blue tip wrench is the only way to go,,IMO. I have hit my hands too many times w/hammers. I use a very small tip cutting torch, off the head then melt out the center. For salvage yard work I use an easy to carry small plumbers torch setup. Brian | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i thought they were pretty easy to remove.my method is to drill through the head with a sharp bit. slice off the head with a sharp chiesel then knock out with a punch.........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | A word of caution.
A couple of months back I drilled off the heads and punched out the remaining bodies of the several rivets holding the rear cross member to the frame on my '41. At this point I should mention that the crossmember had a 4" bow pulled into it. This was probably a result of being pulled out of the mud by some really big truck, tractor, or dozer. So when the last rivet on one side was driven out it SHOT all the way across the garage and put a very nice river shaped hole in my drywall.
Lesson here....The rivets do fill the hole and there is no room for movement when the parts being held together are pulled or pushed out of the original alignment. When the rivet lets go something is going to move very quickly. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think they are easy too. I use a cold chisel that is about 14" long and 1" wide with a good sized cross peen hammer on a 18" handle. Holding the chisel with vice grips allows you to really swing the hammer without worry. Usually only 3 or 4 blows is needed for a 3/8" rivet. Then follow with a punch.
An air hammer with chisel and punch is really nice if you have one and air is available.
Grigg | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think an air chisel would make things a lot easier. I found that some rivets were harder to remove than others. I actually bent a brace pounding the rivet out. | | | | | Joined: Aug 2005 Posts: 124 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 124 | When drilling the rivets(any rivet in general) try not drilling all the way through the rivet, maybe halfway or so. This will leave an indentation or pocket for your punch to fit in, while weakening the fit of the rivet. The punch will stay in the drilled hole when hitting! | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | When removing rivets, don't be afraid to drill through the shank when you have one that doesn't want to punch out. If you are going to put a bolt in the hole, you will need to drill to the bolt size anyhow, rivet hole sizes are not the same as bolt sizes.
Fred 52 3600 69 C-10
