0 members (),
134
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don’t exactly know where to put this, it’s a safety issue but I can’t post any thing there. Back in the 50’s and 60’s when I was a kid, the standard way to wash parts was in a bucket of good old Sinclair regular, with bare hands. Well times have changed and I’m a little bit wiser now but probably still haven’t learned my lesson completely. In recent years I’ve kept a tank of kerosene bought in bulk at the local supplier. I’m still washing parts with bare hands but don’t think it is as bad as the gasoline. It doesn’t seem to dry my hands out to much and if I wash good and put a little lotion on all seems well. At least my hands don’t tingle and go numb like they did with the gasoline, that’s some improvement. Anyone have any “facts” concerning kerosene absorption through the skin and it’s affects? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I think the gas fumes were worse that any absorption. doubt kerosene is as bad. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | 1. never lock your truck 2. leave the keys in it. They usually won't start for a unfamilar person. 3. read step one again. | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | I used to use methylene chloride all the time to wash parts in. No gloves. Hands in it. I'll probably die of it. Can't do nothing bout it now.
My grandparents used to put turpentine on themselves as a remedy for about anything. Before neosporing cream was around, turpentine was the antibiotic. If you sprained something, soak it in turpentine. If you got cooties, bathe in turpentine. They no longer make turpentine from pine sap, so it no longer has the "pine sol" smell about it. You'd probably have your kids removed by the child protection agency if you put turpentine on a cut they got while playing in the yard. Times have changed.
I also washed parts hands deep in kerosene, but find it gives my hands the tingles afterwards. Buy yourself a pair of rubber gloves. They last for a while, not that expensive, and will keep you from stinking as much. I usually do a finish wash with a spash of gasoline to remove any oil or such that was dissolved in my kerosene. This way I end up with clean parts with no oil or kerosene on them that needs to dry. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Skin cancer is the most likely issue when dealing with these chemicals as well as motor oils. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by Builder: Skin cancer is the most likely issue when dealing with these chemicals as well as motor oils. Also very hard on the kidneys,,Brian | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | If you get a hold of a WHMIS book it will tell you to wear proper gloves as these petroleum cleaners are cumulative in your liver. They will eventually kill you ,so use caution and proper protective equpment. Lothar | | | | | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | Here in Germany we use Petroleum in our parts washers since generations.
It is different from what you call Peroleum I belive - it is between crude oil an cerosine - more like Disel oil but without all those additives.
What I like is that you don`t have those dangerous vapours like gasoline.
I even use it to wash my hands.
Remember that Vaseline is nothing but Petroleum Jelly.
The raw material for petroleum jelly was discovered in 1859 in Titusville, Pennsylvania where it was sticking to some of the first oil rigs in the U.S. The riggers hated the paraffin-like material because it caused the rigs to seize up, but they used it on cuts and burns because it hastened healing.
So I belive Petroleum can´t be that bad.
Frank | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Rusty Rod has used gas, diesel ect as a parts cleaner for years with no apparent evidence of harmful after/side effects..... (URK.. goes into convulsions)
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Neither, I use varsol. Cleans like gasoline smells like gojo. Was used in the 1800's as dry cleaning solution on clothes. But so was imbalming fluid. Will burn won't explode. Funny thing but my 1942 shop manuel says use gasoline to clean dirty parts. Uhhhh NO!
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The past 37 years I have breathed gasoline, kerosene, MEK,(methyl-ethel-keytone) copper flouboric, chromic acid, and tons of varsol, also printed using solvents, ethyl alcohol, butyl alcohol, selsove/acetate, and inhalded lots of asbestos (sprayed it on steel beams for fireproofing). As you can suspect..MY GHOST is writing this letter. I died several years ago. None the lest I use the stuff my nephew buys in the big 55 gal barrels for his machine shop. I also like gasoline but mostly use purple power, simply green. | | | | | Joined: Apr 2005 Posts: 28 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 28 | Dad is a retired machinist. Washed parts/pumps in varsol,etc. for years. Now he can't get it on his skin... We should wear gloves... | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I know you asked about skin absorption but the other very important reason for not using gasoline in a parts washer is the flash point. Gasoline has a flash point of -40 degrees while kerosene has a flash point of about 110 degrees. The gasoline can be ignited from a nearby ignition source at most any temperature likely to be in your shop while the kerosene would have to be heated to over 110 degrees for the same nearby ignition source to ignite it.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | I worked for a year delivering fuel oil, and had my share of baths with it. I get sick just smelling the stuff now, 22 years latter.
Mineral Spirits (paint thinner) is a good parts cleaner if you must use something not water based.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | chem. resistent gloves are cheap.
Keith If it were easy they'd have grade schoolers doing it! | | |
