4 members (3800GUY, Peggy M, carbking, 1 invisible), 123 guests, and 2 robots.
Topics128,164
Posts1,056,965
Members48,458
#212824 08/01/2006 3:38 PM
Redryder pix
My Hotrod
#212825 08/01/2006 4:10 PM
so, why isn't it in there ?!
Hello, Welcome to America
press '1' for English
Puess '2' to disconnect until you learn to speak English
#212826 08/01/2006 5:29 PM
Fred,
Those pics are pretty dinky.
Am I looking at a 235 with 3 carburetors?
Cause that's pretty sweet, if a little overkill. grin
I think that you should drop that into ol' RedRyder.
#212827 08/01/2006 6:06 PM
you get a six with the right stuff and it will pull away from a stock 350...........
Redryder pix
My Hotrod
#212828 08/01/2006 6:43 PM
Depends on which "stock 350",
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
#212829 08/01/2006 6:47 PM
Something is real wrong with the second pic.
There is, what appears to be, an oil filter towards the crank pulley and the distributor is way forward of its original location.
What gives? :confused:
#212830 08/01/2006 7:35 PM
Jed Offline
Fred,
I think that would look pretty good in Red-Ryder. You oughta have one made up.
Rattletrap, I don't think there's anything wrong with that pic. Unless you thought you were looking at a 235. I believe that's a little later block, perhaps a 250, or 292?
#212831 08/01/2006 9:15 PM
2 Offline
Joker it wouldn't fit with those 3 carbs on it. You would have to beat out the fire wall to get it in.
Tom
#212832 08/04/2006 5:07 PM
The engine is a 292 late model 6. The position of the oil filter and the "tall" side covers is what gives it away. I have one in my '56 2 door sedan and it surprises a lot of people. It is especially good in the 1/8 mile but doesn't do that bad in the 1/4. It's a full size, complete 3400lb car and will run high 13's at just under 100mph. Not bad for a street driven car, that heavy with that small motor. Mine just has a little head work, a cam, headers and a four barrel.
#212833 08/04/2006 5:10 PM
Tom, I will wait till you get ready for a v-8 and I will buy your nice six.......... grin I know, I probably wont live that long..........
Tom\'s eng
other side
This is Tom's engine mods.........
a 235 with an 848 head for better compression, Fenton hedders with dual exhaust, twin Holley/Webber 2 brl. carbs. The carbs have a small primary for econemy and the secondarys are set up on a progressive linkage. I then installed a 3 speed overdrive transmission from the mid 60's with a 3.90 rear end which gives me a 2.73 final drive in OD. he receientlly drove to Denver from Arlington Texas and averaged 18 mph overall. You can get those carbs for 65 bucks each from Tom Langdon out right. A lot cheaper than a 4 brl carb and better fuel mileage.
Redryder pix
My Hotrod
#212834 08/04/2006 9:23 PM
2 Offline
Fred you are probably right on that wait. One of these days I ought to send in some photos for the gallery. Another roundtuit in the pile.
Tom
#212835 08/04/2006 10:11 PM
hope you dont mind me posting the pix, suspose I should have asked first,, the pix are from our meeting at la-grave field Oct of last yr, cletis bought us lunch,, I thought you had sent some in to the gallery.. I am going to post this pix of mine and yours,, did not take one by its-self and mine may mess up the looks of your 53 but folks here is a shot of my 52 and Tom's 53.....you gotta see his truck in person.....
Fred\'s red chevy and Tom\'s blue chevy
Redryder pix
My Hotrod
#212836 08/04/2006 10:33 PM
2 Offline
Fred , Naw I don't mind at all. I just haven't sent anything into the gallery yet. Thats just the way we drive them in Texas. Right Fred. Thanks for the post.
Tom grin grin
#212837 08/04/2006 10:35 PM
Joker Just one word Sweeeeeeeeet !!!!!
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#212838 08/04/2006 11:56 PM
Tom,
Where did you get that plug cover for the 235? Do they make one that will fit a jimmy engine? Or did you just mill a piece of metal and have it pollished up nice? DETAILS!!!
#212839 08/05/2006 2:31 AM
2 Offline
bigbadswingdaddy, I got the plug cover from Tom Langdon Sotvebolt parts. If memory serves me it was about 35 bucks. Not sure if it will fit a jimmy though. Call Tom and he can give you more info.
Tom
