7 members (Joe H, jaycoop, 2-Ton, 42465967, Southerntruck, Shade Baby, TUTS 59),
125
Mod | | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Ok, probably been asked a few times, but at least it'll be back up top. What do you all recommend for rusted bolt removal besides a drill and cutoff wheels? I've been soaking in Marvel Mystery Oil, and a guy told me to get one of the little auto parts stores blow torch things. He said as long as paint isn't an issue, rust will burn before metal. Is this the best way to get the hard ones? | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I just read the clutch head topic, so that helps. Any others with good solvants for tough bolts appreciated. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I like PB Blaster the best | | | | | Joined: Apr 2005 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 20 | pb blaster goes on everything....including my burgers. it might take a few applications and several hours of soaking sometimes but that stuff is great. i was quite elated to find it in gallon jugs now. | | | | | Joined: Jun 2006 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 49 | PB blaster is indeed great stuff. For those bolts that even that doesn't do it, I use a carbide "burr" in my die grinder. I got it from Eastwood. It cuts quickly with less colateral damage than cutoff wheels. | | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | marvel mystery oil and heat.
| | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=9;t=000304#000000
Jim
Good luck with your project!
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I prefer BG's Enforce penetrant. It's commercial grade stuff so you'll have to buy it from a shop that uses it. If paint damage isn't an issue, I heat the area around the fastener to expand it then put some torque to it to remove it. If you heat the bolt, technically you are expanding it even tighter. Scott | | | | | Joined: Jan 2001 Posts: 7 New Guy | | New Guy Joined: Jan 2001 Posts: 7 | What we use and are very pleased is for the really tough ones try GM General Purpose Penetrant and Heat Valve Lubricant Part 1#1052627 I also have found that the MOPAR Rust Penetrant 04318039AB works equally as well and is a little cheaper. I buy these by the case from the local dealer. I also use heat quite offten. For just the ones that are gummy, lightly rusted I use Sea-Foam Deep Creep. Experiment and see what work best for you. J | | | | | Joined: Jan 2001 Posts: 7 New Guy | | New Guy Joined: Jan 2001 Posts: 7 | Another one that I have use and like is Aero Kroil, I was very pleased with this one. The only reason I don't still use it is it is not avalable localy anymore. I have new one that I have not tried yet, Mouse Milk it comes in a non arosol bottle. Yes I laughed at the name, the guy said you will be impressed, I don't know yet. My personal oppinion for the tough ones the GM or Mopar is the best. I personally feel PB Blaster and WD 40 are a waste of money if you plan to use them for serious penitrating. I am sure they are good for something. Just my thought one past experiances. J | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Thanks everybody. This will be helpful reading for all us new guys coming though these threads. I have been a 60's camaro rebuilder now for many years, but they don't seem to be quite old enough to have such difficult bolt removal that some of these old trucks do. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Tell a kid NOT to take the bolt off, and walk away. It'll be off in ten minutes. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | You asked about a "blow torch thing". I use my cutting torch to heat the bolts up red hot. Then let them cool a bit. Smack the head of the bolt with a hammer, or hammer and punch. They usually come loose. I turn them out a bit, then turn them in, then out, then in, etc. until it comes out. I will use some sort of penetrant to help. That will help break it loose to. If you just put a impact on it and try to back it out without working it back in, many times you will break the bolt off. Patience pays off when you get the bolt out without destroying the hole.
If the bolt extends through the hole and it can be reached from behind, sometimes I cut off the end of the bolt with a thin cutting wheel. That way the whole lenght of the bolt doesn't have be forced through the hole threads.
I have a couple of sets of screw extractors where you drill a hole first and then set the extractor in the hole and try to turn it out. Most of the time I have failures with them. Your just lucky when they work. The one that works the best is a set that comes with its own set of reverse bits. Sometimes a screw or bolt will come out while drilling the hole with the reverse bit. | | |
