| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Want to lift the bed a bit so I can slip the missing rubber pads in place. I won't lift it very high to do it but want to be certain I have loosened/removed all the attaching bolts. I will lift it with the fenders attached.
- the 6 main bolts - the 2 bolts holding the running boards to the rear fenders, - the bracket from the rear fender to the frame - the one bolt attaching the rounded skirt ahead of the wheels to the rear fender.
Have I forgotten any as I don't want a surprise. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | that should not be a big deal check your wiring for slack i would also paint/ varnish the wood blocks to keep them from cracking and rotting out over time heck if you are going to do it do it all..........ONCE
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Good point about the blocks. Thanks. I tried raising the bed by myself (fenders attached) and it seemed to lift the whole rear end a bit. Can't think of anything else holding it down, just the weight of it perhaps. Don't know how I will raise it, probably use a floor jack with a 2 x 4. Any other ideas? | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | olblu49
If you could borrow or rent one of those 'jack-all's' (tractor jack) that might work better than the floor jack and a 2x4------just an idea. I've had one for more than 50 years and it's amazing what uses it can be put to. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Ol Blu,
I just spent the afternoon installing blocks and pads under the 46. If everything is loose, you should not need much force at all. A floor jack should be more than enough. I was able to apply enough force using arm strength only to place the blocks and pads underneath.
Also, if you have an under bed spare, make sure nothing is hanging up on that as well.. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks Jarge. Haven't heard from you in a while. I don't have a 'jack - all' but wish I did. And 46 in Progress thanks for your input. The blocks are there already but I never had the pads. Was thinking of starting at the front of the bed using arm strength and if necessary the jack and raising it about 1", just enough to get the block out and put in the pad and replace the block. Hope I don't bend anything in so doing. If all the bolts I took out line up when I'm done I'll be happy. It will be a one-man job. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Big pry bar and a couple of 2x4 bits? Expect things to be a bit rust welded together. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Removed the whole box with 4 friends, piece of cake probably only weighes 3-400lbs and lifts quite easy. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | But I ain't got no friends! Seems everyone is 'suddenly' busy! | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Got all the bolts out, used a jack to raise the rear an inch. Put the blocks and pads and those 4. Lowered it and raised the front. Here is where the problem is. The long bolts go through the blocks and pads and into the top hole of the frame but are not lined up with the bottom holes in the frame. About half a bolt distance. I had not tightened the rear bolts so I pulled them out hoping to jog the box but it would not move enough. Pulled the bed boards out so i could get a better look at the problem. Wonder if I took a reamer and enlarged the lower hole to accommodate the bolt would be all right. As of now I have put her away until I get in a better mood and have more help. Hardly a one man job in my case. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Took a long break from and wondered what I was doing wrong. Realized that although I had drilled the holes in the pads the same diameter as the bolts, rubber has a tendency to 'shrink' after you drill it. My bolts were not getting through the rubber. I took them out and made a square cut in the rubber and the bolts dropped right in. All bolted up now. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 |
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I removed and replaced my bed by myself.. just used a hand truck to move it around, then levered it up into place... (no fenders)
| | | | | Joined: Apr 2006 Posts: 51 Member | | Member Joined: Apr 2006 Posts: 51 | ol blu, maybe i can exchange labor with you on a few things...and/or knowledge
old iron vs. new plastic....no brainer! TECH WANTED: on S-10 frame swap PARTS WANTED: 54 Visor, weather strips.. PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate 1954 GMC 3100 | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Tony - any time. Two heads are a lot better as are 4 arms. Let me know. | | |
