0 members (),
347
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 45 Member | | Member Joined: May 2004 Posts: 45 | Here's what I've got. '54 chevy, original 235 engine, 4 speed granny in the floor- all in excellent shape. I need to pull a 2 axle trailer with 2000 boat, surge brakes on trailer. If I put the largest shocks I can find on the rear end, and I make sure the drum brakes are in very good shape, can I safely pull this load? I'm not talking about pulling the Rockies- just mild rolling hills. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Sure, why not. I've seen people pull bigger boats with smaller trucks, a 'Bolt'll do it just fine. Wire it up for trailer lights and put a good hitch on it, you'll be fine. You may have to fabricate or modify a hitch to fit.
Bill Burmeister | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Remember to give yourself some braking room when towing with drum brakes. Other than that should work just fine.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | When I was a kid in the 60's we pulled a boat or a travel trailer all over the place with our '58 1/2 ton with a 235. No problems that I remember. | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Oct 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 42 | I have a 1950 1-ton dually, 216 with 4 speed, we pull 4 horses in a goosneck with no problem. Top end an incredible 50 mph but it get's it done.
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I wouldn't even worry about putting different shocks on if yours are working. | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | You can in a pinch do even more with a bolt. When i was young we hauled hay wagons, and raked the hay with a 3/4 ton. I even hooked up a 2 bottom plow one time and plow a little with one. When pulling sometime that hard it will heat up on you if you dont have a good clean cooling system. You should be able to do most anything a modern truck does with your bolt, after they were all there was once upon a time. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | When I was a kid...my dad had an early 50's GMC. We pulled an 18' runabout - single axle to the mountains often. The bed was full of camping gear, me, and my brother. We probably didn't break any speed limits but I recall it hauled just fine. Sounds like you are pulling more weight though.
40 Chevy 1/2 ton
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | So? Do you have to put 6 volt bulbs in all of your trailer lights or does everyone upgrade the truck to 12 volts? Scott | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I have pulled several heavy loads in various trailers with my 61. It has a 235 with a 4 speed in it. Does an admirable job, brakes are a little chancy, I feel better towing a trailer that has its own brakes than just a dragger. I would feel comfortable towing a boat with my truck, so long as I did not need to get on the freeway. Go for it!
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I sometimes pull a small 14' boat around. Boat, motor and trailer weigh about 1200 tops. I can only tell it's there it on the really steep hills. | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Originally posted by highwayman: Remember to give yourself some braking room when towing with drum brakes. Other than that should work just fine. yep these old "bolt" brakes work hard to stop "just little ol me", but I think the Boat and trailer would need a little extra time and distance. Cliff59 | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | use your gears to help slow down and take it easy it will do fine | | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | These are trucks for crying out loud! They were built to work! I used to pull a 18 foot car trailer with my 66 C20. Pulled hay wagons and a 2 horse trailer with a 85 S-10 15 years ago. | | | | | Joined: May 2004 Posts: 45 Member | | Member Joined: May 2004 Posts: 45 | Ok guys-you convinced me. Taking the Chevy to Myron the weldor today to get fixed up with a hitch. Then shock upgrade probably. Yes I've gone over to 12v long long ago- in fact its based around a Painless system. | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Hey ya know, these trucks were made to work. Changing shocks should not be ness. if you shocks are in good shape. My only conserns would be is my tow vehicle heavy enough to stop a large load and do my surge brakes work. Surge brakes are ok if you have a good brakeing system on the tow vehicle, at best a 54 1/2 ton had ok brakes. I would add an electric brake system to my trailer. Just my 2 cents. James
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Unless you are putting shocks with overload springs or air overload, the shocks make no difference in towing or load capacity. Normally the early ton and a halfs came without rear shocks. | | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | My Dad dropped 3 complete Olds 455 engines from the wreckers into the back of my 58 1/2 ton. I had to drive around town for a week before he came and got them.
I had almost no accelleration but I had unbelieveable traction on the steep and snowy streets of Medicine Hat, Alberta. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've pulled a loaded car trailer behind my '55 1st GMC Suburban. GMC 270, SM420 and 3.08 gears under the rear.
With 70's vintage drum brakes on the rear and disks on the front, slowing it down without a brake controller can seem scary and I don't think I'd choose to do it again.
With my rear gears running 70+ on flat ground with an empty trailer isn't hard. But it sure can be slow to accelerate, especially once I get a load on that trailer.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | Nahhhhhh ya's gots to push a boat..hehehe
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
