1 members (mick53), 202 guests, and 1 robot.
Topics128,115
Posts1,056,288
Members48,439
#209902 06/13/2006 8:01 PM
Here's what I've got. '54 chevy, original 235 engine, 4 speed granny in the floor- all in excellent shape. I need to pull a 2 axle trailer with 2000 boat, surge brakes on trailer. If I put the largest shocks I can find on the rear end, and I make sure the drum brakes are in very good shape, can I safely pull this load? I'm not talking about pulling the Rockies- just mild rolling hills.
Sure, why not. I've seen people pull bigger boats with smaller trucks, a 'Bolt'll do it just fine. Wire it up for trailer lights and put a good hitch on it, you'll be fine. You may have to fabricate or modify a hitch to fit.
Bill Burmeister
Remember to give yourself some braking room when towing with drum brakes. Other than that should work just fine.
38 original
48 panel
59 stepside
46 in the back forty
When I was a kid in the 60's we pulled a boat or a travel trailer all over the place with our '58 1/2 ton with a 235. No problems that I remember.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
I have a 1950 1-ton dually, 216 with 4 speed, we pull 4 horses in a goosneck with no problem. Top end an incredible 50 mph but it get's it done.
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
I wouldn't even worry about putting different shocks on if yours are working.
I
I Offline
You can in a pinch do even more with a bolt. When i was young we hauled hay wagons, and raked the hay with a 3/4 ton. I even hooked up a 2 bottom plow one time and plow a little with one. When pulling sometime that hard it will heat up on you if you dont have a good clean cooling system. You should be able to do most anything a modern truck does with your bolt, after they were all there was once upon a time.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
When I was a kid...my dad had an early 50's GMC. We pulled an 18' runabout - single axle to the mountains often. The bed was full of camping gear, me, and my brother. We probably didn't break any speed limits but I recall it hauled just fine. Sounds like you are pulling more weight though.
40 Chevy 1/2 ton
So? Do you have to put 6 volt bulbs in all of your trailer lights or does everyone upgrade the truck to 12 volts?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I have pulled several heavy loads in various trailers with my 61. It has a 235 with a 4 speed in it. Does an admirable job, brakes are a little chancy, I feel better towing a trailer that has its own brakes than just a dragger. I would feel comfortable towing a boat with my truck, so long as I did not need to get on the freeway. Go for it!
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
I sometimes pull a small 14' boat around. Boat, motor and trailer weigh about 1200 tops. I can only tell it's there it on the really steep hills.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Quote
yep these old "bolt" brakes work hard to stop "just little ol me", but I think the Boat and trailer would need a little extra time and distance. grin
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
use your gears to help slow down and take it easy it will do fine
These are trucks for crying out loud! They were built to work! I used to pull a 18 foot car trailer with my 66 C20. Pulled hay wagons and a 2 horse trailer with a 85 S-10 15 years ago.
1965 Chevy C-10 Longbed Stepside
Ok guys-you convinced me. Taking the Chevy to Myron the weldor today to get fixed up with a hitch. Then shock upgrade probably. Yes I've gone over to 12v long long ago- in fact its based around a Painless system.
Hey ya know, these trucks were made to work. Changing shocks should not be ness. if you shocks are in good shape.
My only conserns would be is my tow vehicle heavy enough to stop a large load and do my surge brakes work. Surge brakes are ok if you have a good brakeing system on the tow vehicle, at best a 54 1/2 ton had ok brakes. I would add an electric brake system to my trailer. Just my 2 cents. James
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Unless you are putting shocks with overload springs or air overload, the shocks make no difference in towing or load capacity. Normally the early ton and a halfs came without rear shocks.
My Dad dropped 3 complete Olds 455 engines from the wreckers into the back of my 58 1/2 ton. I had to drive around town for a week before he came and got them.
I had almost no accelleration but I had unbelieveable traction on the steep and snowy streets of Medicine Hat, Alberta.
I've pulled a loaded car trailer behind my '55 1st GMC Suburban. GMC 270, SM420 and 3.08 gears under the rear.
With 70's vintage drum brakes on the rear and disks on the front, slowing it down without a brake controller can seem scary and I don't think I'd choose to do it again.
With my rear gears running 70+ on flat ground with an empty trailer isn't hard. But it sure can be slow to accelerate, especially once I get a load on that trailer.
Nahhhhhh ya's gots to push a boat..hehehe grin
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
