0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | With my ongoing radial tires/versus stock rim size battle I have found some aftermarket steelies from a well known company that are 16 x 6". They will not take my stock hub cap but they are brand new, welded rims with a safety bead. My question is about the 6" rim width and how, if any ill effect, it would have on my stock spindles and rear axle? The tires would be 215-85R16. Bill | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I can't imagine they would be an issue. | | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | Bill, I'm NEEDING rims like those, can you tell me where you found them and have you checked the offset to make SURE they'll bolt up and actually turn on your old truck? Oh, I need 8 holer's, is that what you are talking about? Any help will be appreciated, thanks, randy | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Randy these came from Wheel Vintiques but they are 6 bolters. I have not checked offset, asking for a normal wheel. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Randy you raise a good point about these wheels actually fitting even though they are 16" with the right lug hole pattern. Until I actually get to try one I won't know if they do have the right offset or backspacing. I guess I could measure the backspacing on one of my stock wheels and see if it is the same on the aftermarket one. I just thought I would order a set with standard offset. Anybody have any better ideas or advice? | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | Bill,
I believe Stockton Wheel could weld later model rims on your existing wheels and solve your problem. That is what I did on my truck in order to have disc brakes and keep my stock wheels and hubcaps, because I ran into the offset issue with my stock rims and not enough clearance for the caliper.
I know mine are 15"s not 16", but I would think they would have a 16" rim that would work with your existing wheel. It would be worth a phone call. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks Jim. They can do all that and I have spoken to them. They are on my list of 'potentials'. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks Jim. They can do all that and I have spoken to them. They are on my list of 'potentials'. What I am wondering now is about offset and back spacing. I think if the wheels are widened on the inside the tires may rub the tie rod ends. I can get the wheels I want but they have to be ordered and if they don't work I am stuck with them. The price up here would work out to about $500 for the wheels including taxes. That is okay if they fit but out of my budget if they don't. Bill | | |
