| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I cant find the old post on this,I have my new oak boards and I want to have a nice gloss finish to them, someone suggested to buy a automotive polyurathane,I have been to Napa,carquest,and autozone. They have never heard of this product Did I get sent on a snipe hunt to buy a sky hook or does this really exsist. All Ideas welcome | | | | | Joined: Jan 2006 Posts: 21 Junior Member | | Junior Member Joined: Jan 2006 Posts: 21 | It exists--I've seen it. But I don't know that its appropriate with wood.
Taco
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Ive heard this also. I planned to use automotive clear coat on my wood when the truck is ready for it. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Can't say that I've heard of it except as it would apply to automotive paints. Might be available in clear and perhaps thats what the guy meant.
I used the recommended marine spar poly varnish on my pine floor and it's not holding up well at all. Three coats and still doesn't look right. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Check over in the "Making a Stovebolt Bed" Forum... lots of discussion going on about finishes there. Bed supplier Mar-K has also been experimenting with different finishes. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Mar-K has pictures of my bed on their web site and I just used regular poly with a lot of wet sanding between. Looks good after 2 years but am going to wet sand and give it another coat this year | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Marine Spar Varnish - about 10 coats brushed on with light sanding between coats will give you a long lasting finish. My finish is on for ten years and it looks new. Here is the key - you MUST do both sides and the edges of all of the boards. In other words, encase them or seal them totally! That will do the trick. Look at my bed and side boards on the link below! It's perfect and I did it in 1997. I was told to do it this way by a paint manufacturing company tech. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | I'm in the middle of this job. Oak bedboards. I'm using Sikkens Cetol Marine Light...four coats...followed by 3 coats of Sikkens Marine Gloss. Sold in marine supply stores. Goes on very smooth and even, with a nice light tone and good UV protection. What I really like is the mfg recommends no sanding between coats. I did another set of oak bedboards years ago with a highly rated marine spar varnish, sanding between coats, etc and this Sikkens stuff looks better. COmpletely agree with Joe that all surfaces must be coated. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Thanks for the info, Marine seems to be the way to go,scince I live on the lake I will visit the marinas. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I used the marine spar varnish and mine looked good after 8 years with 4 good coats on all sides. On the Mar-K Bed forum he suggest using a primer before the spar urethane. I think the post was around Jan 20th as I ask the same question as you when I wanted to freshen up mine. On that post Mar-K list the experiments that have been done, how long they have been in process and so forth. It is a good read. Just more info!! | | |
