1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#206356 04/19/2006 10:49 PM
Junior Member
Junior Member
Okay heres the deal, I have 59' apache im trying to sell, i just put a brand new custom driveshaft on it and i wanna take it a step further, my exhaust leaks like you wouldent belive as it is, sounds nice but i loose so much power. i have a 350 small block out of an 81 chevy suburban, and my frame is from the same vehicle, i want to put block hugger headers and get some 3 inch pipes, they dont have to be stainless or anything fancy like that, just in functional shape and able to fit my frame without too much hassle, where should i go for my pipes? im postive i can find hugger headers with a 3" output on ebay but i cant seem to find pipes that would fit, the space between the frame and the block is tight so i definatly need the huggers, so basically, what kind of pipes should i get, and from where?
#206357 04/19/2006 11:19 PM
Find a local shop that bends their own tubes, more than likely they'll be cheaper than pre-made pipes would be. Also you can show them how you want them run. I don't know about in FL but here they'll let me in the shop when they have it on the lift to show how I want the pipes routed. Good luck.
Rob
#206358 04/20/2006 5:27 AM
Junior Member
Junior Member
mufflers or not? i was thinking about getting a used pair of super 40s like this http://cgi.ebay.com/ebaymotors/Flow...3589QQcategoryZ33636QQrdZ1QQcmdZViewItem
#206359 04/20/2006 5:40 AM
If you're going to sell it,why the 3"pipes? I'd get a 2-1/2" set on it and call it good. Chances are,whoever you sell it to will want different pipes/mufflers/sound/looks anyway,so save yourself the money and hassle,just give it a standard fresh exhaust system and let the buyer spend HIS money to make it "better".
Just my opinion.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#206360 04/20/2006 6:21 PM
If your selling it get it out the door as cheaply as possible. You wont get the extra $100 or so you stick into it.
#206361 04/21/2006 10:59 PM
Riding in the Passing Lane
I agree. Go to a muffler shop & let them build a system. Unless you are going raceing 2-2 1/4" pipes would be large enough, sound better & be a neater installation. I like long glasspacks.
1972 Chevy c10 Cheyenne Super
#206362 04/24/2006 1:49 AM
You don't need 3" pipes in a truck! I also have a '59 Apache with a 350 engine. I 'tuned' the pipes to a specific RPM level (3500 RPM) by using the diameter of the pipes to build a reverse sound wave to 'extract' exhaust at a given RPM for a given displacement. I use the formula:
1" of diameter per cubic inch of displacement for 7000 RPM for the whole engine. I use my engine at 3500 RPM max, therefore I only need half the calculated value at 7000 RPM. Therefore, I wouldn't go over 2" diameter pipes if I were you.
Regards,
