1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 24 Junior Member | | Junior Member Joined: Mar 2006 Posts: 24 | Okay heres the deal, I have 59' apache im trying to sell, i just put a brand new custom driveshaft on it and i wanna take it a step further, my exhaust leaks like you wouldent belive as it is, sounds nice but i loose so much power. i have a 350 small block out of an 81 chevy suburban, and my frame is from the same vehicle, i want to put block hugger headers and get some 3 inch pipes, they dont have to be stainless or anything fancy like that, just in functional shape and able to fit my frame without too much hassle, where should i go for my pipes? im postive i can find hugger headers with a 3" output on ebay but i cant seem to find pipes that would fit, the space between the frame and the block is tight so i definatly need the huggers, so basically, what kind of pipes should i get, and from where? | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | Find a local shop that bends their own tubes, more than likely they'll be cheaper than pre-made pipes would be. Also you can show them how you want them run. I don't know about in FL but here they'll let me in the shop when they have it on the lift to show how I want the pipes routed. Good luck.
Rob | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | If you're going to sell it,why the 3"pipes? I'd get a 2-1/2" set on it and call it good. Chances are,whoever you sell it to will want different pipes/mufflers/sound/looks anyway,so save yourself the money and hassle,just give it a standard fresh exhaust system and let the buyer spend HIS money to make it "better". Just my opinion. Speed | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | If your selling it get it out the door as cheaply as possible. You wont get the extra $100 or so you stick into it. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree. Go to a muffler shop & let them build a system. Unless you are going raceing 2-2 1/4" pipes would be large enough, sound better & be a neater installation. I like long glasspacks. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | You don't need 3" pipes in a truck! I also have a '59 Apache with a 350 engine. I 'tuned' the pipes to a specific RPM level (3500 RPM) by using the diameter of the pipes to build a reverse sound wave to 'extract' exhaust at a given RPM for a given displacement. I use the formula:
1" of diameter per cubic inch of displacement for 7000 RPM for the whole engine. I use my engine at 3500 RPM max, therefore I only need half the calculated value at 7000 RPM. Therefore, I wouldn't go over 2" diameter pipes if I were you.
Regards, | | |
