| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 7 New Guy | | New Guy Joined: May 2005 Posts: 7 | ok here's the problem my spark plugs were fouled up.I took them out and cleaned them. The truck started fine. I adjusted the idle.Turned it off and tried to restart it. no such luck. i pulled one of the plugs back out and its fouled again i know i'm running rich but other than adjusting the idle i 'm not sure what to do. so any suggestions on how to adjust the fuel mix so i'm not running rich? oh also i have an electric fuel pump on it. could that be part of the problem?
"the red things just hold up my halo"
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Before we can aswer that, we need to know some stuff. Which engine are you running? Which Carburetor do you have?
I have a Carter W-1 on a Chevy 216. On the back side of my carburetor there is a screw with a spring that you turn to mess with the mixture. This information may or may not be what you're looking for. If you've got a 50's era carb, you may have a Carter Y-F or a Rodchester, and neither of those, AFAIK, are the same set up.
Lots of people have electric fuel pumps, so I doubt that this is the issue. If the Carb were clogged up you'd have overflow, but that's the same with any fuel pump.
Welcome aboard, BTW! We can probably get you straightened out without too much trouble. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Is the choke plate open or closed? | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Is the float level too high? Is the plug black in color or wet? What type of plug are you running and what is the gap set at? Do all the plugs look the same or is it one or two? | | | | | Joined: May 2005 Posts: 7 New Guy | | New Guy Joined: May 2005 Posts: 7 | Its a Rodchester carb. I tried both open and closed.The choke is a little touchy it likes t be in a certin spot. The plugs were black when I took them out. One was worse. There was enuff bild up that I could tap on it and some of the build up would fall out. I think that one was my #6 closest to the fire wall but that was before I cleaned them now they’re all black none worse then the other.Champion plugs As for the float level and the gap i dunno.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 |
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Go along with I.B. think the float is stuck. | | | | | Joined: May 2005 Posts: 7 New Guy | | New Guy Joined: May 2005 Posts: 7 | ok thanks for the help guys!!i'm sure i'll be needing it again!!
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Tell us more about the choke. Do you have to run the thing with the choke on to run right - or just pulled out a certain extent? Could be you have some air leak, and fatting up the mixture with the choke could be dumping fuel in there. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | How good is the spark at cranking speed? If you're not getting enough juice to the ignition system when you crank it over,it might start when everything the plugs are at their best,butif the float level is a little high or if the float sticks once you shut down it might pull enough unburned fuel into the engine to foul some plugs,and with weak spark,when you try to re-start there's not enough spark to clear the plugs. Speed | | | | | Joined: May 2005 Posts: 7 New Guy | | New Guy Joined: May 2005 Posts: 7 |
| | | | | Joined: May 2005 Posts: 7 New Guy | | New Guy Joined: May 2005 Posts: 7 | Well the float was where it should be. But when I put it back together, I cleaned the plugs again and she fired up 3 times in a row!! I think when I put the choke line back on I gave it some extra room to move. Now the choke doesn’t have to be in that sweet spot to start. I just had to use the choke to get her started. But now I think my other wheel cylinder has blown because I’ve lost the breaks again. Oh well another issue for another day. Well thanks for all the help everybody.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Hey neighbor. Make shure there is a notch in the carb. base gasket for the vacuum to reach the hole in the bottom of the carb. If you need any help with it e-mail me. I,m not too far away. [email protected] They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | elect fuel pump could have more pressire than the old float and needle can handle. flooding by high fuel level in the bowl.
"It ain't a truck if you can't hose out the cab."
