| | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | i'm paintin the engine trans and t-case out of my suburban before i put my 64 chevy pickup body back on and the trans and t-case was simple engine degreaser, pressure wash, then sand blast, so now i'm wonder how to do the engine i'm tempted to do the same as the trans and t-case but for those of you who have sand blasted you know it gets everywhere so.... what to do? (whats a good engine degreaser? the stuff i used was alright.. maybe i didn't leave it soak enough but by the smell it seemed like i was just spraying diesel fuel on it) thanks Nate | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I wouldn't sand blast any mechanical assembly unless it was being totally disassembled and cleaned afterword. Because like you said...the sand gets everywhere. Sounds like you'll need to do some scraping and scrub brushing in addition to just spraying degreaser and hosing it off. Years of caked on crud takes some elbow grease to get off... | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Easy Off oven cleaner works pretty good. Don't get it near any paint you want to keep.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Jan 2006 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 67 | penetrating type degressers and many other degreasers are at NAPA and local auto parts stores. try getting some of the biodegradable, environmentally-friendly grease and gunk cutters, so you can do this in the yard, driveway, ect. and just hose it off the ground afterwards.
red (mostly) 1963 chevy shortbed stepside
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I expended a LOT of elbow grease, a few bottles of degreaser, a half bottle of Simple Green, and a wire brush attachment on my drill. Pretending it's your ex's face makes the work easier ..... | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I used a series of wire brush attachments for my Dremel tool to get every bit of crud off. I also use oven cleaner as a degreaser/paint stripper, Scott | | | | | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I do all my engines with Por15. (the normal Por not the Por Engine Enamel).
The paint is excellent but surface have to be absolutley grease free or you can peel of the Por15 like duct tape.
The only thing that works for me is break claner.
Frank | | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | Bilge cleaner Get it at your Boat Parts Dealers Dissolves oil, grease, gasoline, diesel fuel sludge. And it is Biodegradable environmentally friendly formula. or the old stand by carburator cleaner
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
| | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | thanks a bunch i was thinkin i wasn't doing it all quite right but it guess it really is a pain in the arse but anyway could i still pressure wash? because i'm almost positive water will leak in through the valve covers and i know that tin foil is a good thing to use on the dizzy and carb but anything else that i'd need to take care of before i pressure wash? also anything after? thanks again Nate | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | You shouldn't have any problem using a pressure wash if you have the valve cover down snug. Just plug any holes you might have in the valve cover and use a towel, can, or rag around the carb. If you still have some old paint left on the block, don't worry about it. The new paint will cover it fine and won't pull away as long as the gloss has been taken off and its super clean. I covered some old paint on my engine and have never had a problem with it. Cecil......... | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I would pressure wash it real good and when it is dry, wash it with metal etch keeping it wet for 10-15 minutes. Then wash it again with your pressure washer before the metal etch drys. Wipe off with clean towels and blow with compressed air until it is dry. I like to run a fan on it for a while to make sure I have it real dry. The bare metal will have a green tint to it when dry. Ready for paint. | | |
