2 members (NJC, baldeagle),
33
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 15 Junior Member | | Junior Member Joined: Mar 2006 Posts: 15 | I have replaced all brake shoes and wheel cyl new master new brake lines bled brakes and still no brakes took to shop had brake fuild changed and brakes bled and they adjusted the pads all the way out so they were rubbing hubs and now my brake pedal goes all the way to floor Still no Brakes | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Sounds like you've got a leaky brake line or a hugegantic bubble in the system.
When you pump the brakes, does the pedal come back?
If not, then check your brake lines. Verify that all of your connections are tight and you don't have brake fluid leaking from a line break somewhere. Then go ahead and rebleed your brakes. You should be golden. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Jim,
Your post says they adjusted them all the way out to the point where they rubbed. How about to the point where they drag or decrease the ability of the wheel to turn?
Does the master cylinder always need fluid? How about a puddle of brake fluid on the floor? | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Do you know if they replaced your fluid with DOT 3 or did somebody talk you into DOT 5? If they used DOT 5 you could need to drain the system again, replace parts, and start over with DOT 3. (It's a stretch, I know.)
Otherwise, it sounds like you have a leak. If you leave it parked for a day or so, you should see it pooling on the garage floor. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Make shure you have a little free play before the pedal starts pushing the master cyl. piston.It must come all the way back. If thats ok you still have air in the system or got a defective master cylinder. I have never used them but something like this would be a good place for the bleeders with check valves. I think they call them Speedy- bleeders. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | Jim Did you have brakes before you started? Are you running a factory setup, drums all the way around or do you have power brake with disc on the front? Did the pedal go to the floor before you took it to the shop? You could pull one of the drums off and see if the wheel cylinder moves when you step on it.
New deal for old steel
| | | | | Joined: Mar 2006 Posts: 15 Junior Member | | Junior Member Joined: Mar 2006 Posts: 15 | I do have factory setup drums all the way around truck has been sitting for 1 month no fluid on tires or drive way when I push pedal down it does come all the way back up the fluid I'm useing is Dot 3 yes I did have brakes before I started this job but 2 cylinders were leaking that's why I started this job And I have pulled off both rear wheels and both wheel Cylinders are moving I replaced brake lines on front and one side on rear | | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | Hey Jim59, check the master cylinder and see if you have fluid bypassing the cups. If you do the rear of the master cylinder will be wet right at the point where the plunger meets the master cylinder.
Also be sure the bore size of the new master is the same or larger than the bore size of the wheel cylinders. If not the wheel cylinders will be robbed of fluid before they can expand enough to make proper contact.
Hobert
"The Lord is my shepherd"
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If everything else checks out, you could have a defective master cylinder. These things are put together by human beings and ....., well you know the rest of the story. The wrong cup and piston would give you a lot of trouble. A defective residual valve would allow air in through the wheel cylinders when the pedal is fully released. | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | sounds a lot like air in the system. bleed the brakes properly, and if that is not the problem, redo the master cyl.
"It ain't a truck if you can't hose out the cab."
