9 members (78buckshot, Phak1, Leo, Gdads51, dt235sd, Jon G, mick53, 4tttt8, Otto Skorzeny),
93
Mod | | | Forums66 Topics128,181 Posts1,057,180 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Greetings everyone.
Over the years here, I see less folks running the old 216 in their trucks.
I would like to find out who else here runs stock 216's and drivelines in their truck or car.
My 216 runs like a champ.
Who else has got one?
Greg Falls
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I have one in mine and it runs like a champion. | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | My 42 pick up will have the original 216.I can't till it's on the road. | | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Hey my 42 3/4 ton also has original 216 engine and it runs great. (just wish the truck did right now). Other than a fairly rapid cylinder wall wear rate, these engines are bullet proof....and replacement engines can be picked up for next to nothing. I love em'
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | the 46 burb still has it. the 52 gmc still has its 228 also both work great! | | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | I think I do. How do I find out ? Jeff | | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | My 41 still has the 216. Great engine.
Bob | | | | | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | I have a nice running 216 in my 1951 1/2 ton. The cylinders have sleeves in them and I have insert bearings now. Good and strong, but with stock gears and driveline, I run slow. But since I am retired, who's in a hurry! BW | | | | | Joined: Aug 2005 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 73 | I'm taking a perfectly good 216 out of one 38 and putting it in another  | | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | My '46 hasn't got the original 216, it's a 1953 216, but it's running fine. I do have a two-carb intake manifold and some dress-up items though. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Niagara,
I've got 2 Splash engines. a 39 216 in my 46, and a 48 235 in one of my 52's.
I like em. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Pick me! Pick me! 68 years old & going strong...with the exception of a small electrical problem.
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | My 39 3/4 T runs fine, after i drained the water emolsion from the crankcase. Having problems with the three brush generator. but plan to go modern with one from a 54.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Jul 2005 Posts: 135 Member | | Member Joined: Jul 2005 Posts: 135 | I'm running a stock 216 in my 1949 3800. It was rebuilt before I bought the truck in 1997.
I do plan on installing a 235 this year but will not retire the 216. Instead it will go into another vehicle that is driven locally instead of cross country as the 3800 does when the need arises.
Word hard, play harder, enjoy life!
| | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | My 1940 3/4 ton still has the original 216, 3 speed tranny and torque tube drive line. Top speed is 45 - 50. The engine runs great, like a sewing machine. If it ever blows up (doubt it) I would probably replace it with another if I could find one near by. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I rebuilt my original 216, two years ago. When the truck is finished, that is what I will be using. I must say thatthere was very little cylinder wear at 78,000 miles. I did however convert the rods to inserts. here are some shots of my project along the way: http://community.webshots.com/user/fnixon1 | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Mines got it! And shes runnin strong at about 60K miles to! Never rebuilt. No chance of changin either, cause its original! -Jeff | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | 46 chevy school bus 35 year nap woke it up a bit grumpy at first but runs like a well rested race horse. Who needs 235 ci's when all the 216's are out there to kick their butts. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | stock 216 in the '46 1/2 ton, and stock 235 in the 2 ton.. haven't given me any problems untill recently, when the 1/2 ton didn't wanna start for a bit.. but that's probably all my fault, anyway.
Fired right up today every time I hit the stomp start, and purred like a kitten.
Still seriously considering going with a newer rear and an "open" drive line.. but so long as she keeps running nice, i'll keep it.
If I ever do have to replace the engine, i'll go with a later full pressure 235, or maybe a 261.
| | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | My 1950 3/4-ton has it's original 216. I woke this truck up after a 27 year nap. Still have some work left to get it "on the road" but 216 runs great.
Professional Novice
