| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 16 Junior Member | | Junior Member Joined: Feb 2006 Posts: 16 | Hi there! I am new to the forum.  I also have a queastion to ponder. I have been offered a 1941 Chevy one ton dump by a friend of my dad's for $450. The truck is still pretty solid, but someone stuck in a F*** 390 V8 and 4 speed tranny years ago. I have a 216 I can use for it with a bell housing swap and if I find a chevy 4 speed to fit in it. My question is this: This truck has 18 inch wheels and tires and it has a flat frame in the back instead of the humped up frame most 1 tons have. Also, the rear end under this truck is pretty hefty. My dad has helped work on this truck several times over the years and he thinks it might be more of a ton and a quarter instead of just a one ton. Would this be possible? I do have some piccies of it if I need to post them and I am waiting for the owner to get back from florida so I can purchase the truck. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Sim, Would you have the serial number? We should be able to figure it out with that. Welcome to the bolt page. It is always nice to have another 41-46 fan on here... Also...dump that dorf engine  | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | sounds like a good find. odd that someone put a 390 in it, but that is a solid working motor. It would be cool if you put a 216 into it. I think that any old truck is worth about what you are paying, espescially if that is what you want. go for it and have fun. welcme to the stovebolt page.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I suspect any Chevy/GMC transmission up to the mid 60's would work;Fumblin'46 would be more help on that. Providing it's in decent running order,you can probably sell the 390 for enough to buy all the replaceables for your 216 install(clutch,water pump,tune up,fuel pump,carb kit,alternator conversion,etc.),maybe a tank of gas,too.Good find! Enjoy! Speed | | | | | Joined: Jan 2005 Posts: 24 Member | | Member Joined: Jan 2005 Posts: 24 | if it is all ready a v8 how about a chevy v8 | | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | Welcome simbalion!! I dont think you can go wrong at that price. Hobert
"The Lord is my shepherd"
| | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Welcome aboard! Good luck with your new rig sounds like you got it at a good price. | | | | | Joined: Dec 2005 Posts: 47 Member | | Member Joined: Dec 2005 Posts: 47 | Sounds like a great deal. I would go back original myself but V8 power has advantages. Good luck with the project.
Heres to us and those like us, theres darn few left.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Sounds like a good deal. Anything that runs, even if it's the wrong motor, should be worth that much. Go for it! | | | | | Joined: Feb 2006 Posts: 16 Junior Member | | Junior Member Joined: Feb 2006 Posts: 16 | Thanks for the warm welcome! I will have to get the serial number next time I see the truck. I hope that is soon. | | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | | | | | | Joined: Mar 2006 Posts: 104 Junior Member | | Junior Member Joined: Mar 2006 Posts: 104 | | | | | | Joined: Feb 2006 Posts: 16 Junior Member | | Junior Member Joined: Feb 2006 Posts: 16 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | looks like a ton and a half, w/ the bigger front fenders, might even be a 2ton w/ that nice lookin dump - if yer interested in that kinda truck don't pass it up!
Bill | | | | | Joined: Feb 2006 Posts: 16 Junior Member | | Junior Member Joined: Feb 2006 Posts: 16 | The original wheels on the rear are 8 bolt 18 inchers. Someone changed out the 18 inchers on the front for later 16 inch rims. I have seen other earlier one tons with 18 inch wheels and tires. The dump bed looks to be original. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Welcome to the 'bolt. Cool old truck. Lots of character! Hard to tell really without the body serial number. The ID plate should also have the GVW. With the 8 lug bolts I'm guessing 1 ton.
Professional Novice
| | | | | Joined: Feb 2006 Posts: 16 Junior Member | | Junior Member Joined: Feb 2006 Posts: 16 | A little correction on the 1 ton. I have come to find out that it is a 1946. I am going to finally try and buy it soon. | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | All Chevrolet 4 speed transmissions from 1933 to 1947 will interchange as there is very little difference in them other than casting numbers.
34 & 35 trucks are the greatest
| | | | | Joined: Feb 2006 Posts: 16 Junior Member | | Junior Member Joined: Feb 2006 Posts: 16 | That's good to know. The problem around here is finding parts from any make of truck in that era. Too many had the original running gears ripped out for modern parts. You probably see more 49 and later Chevys around here than the earlier ones for some reason. | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | 1 tons and up had a "flat frame" in back with no hump over the rear axle... so that makes it correct for being 1 ton or larger.
The 18" wheels... well I'm not a pro on this year truck but that usually means it's a 1 1/2 or 2 ton truck.
Nice looking truck. For $450 it's worth it, IMHO.
Figure out what you want to do with it. If you want an original restoration, then you have lots of rare parts to find and buy (big $). If you want a resto/mod then your parts will be cheaper and it will be a more user friendly truck for todays roads. If you want a hot rod... well sell it and buy a 1/2 ton. | | | | | Joined: Feb 2006 Posts: 16 Junior Member | | Junior Member Joined: Feb 2006 Posts: 16 | I have seen other 1 tons from the 30s thru even the early 50s that had 18 inch tires. Dodge is the earliest I have seen to use the more standard 16 inch arrangement. These skinny 18 inch tires do give the truck a neat look and a 16 inch wheel will not fit over the rear brake drums. The at least lets me know the rear end housing is original. | | |
