6 members (Gdads51, J Lucas, Shade Baby, Lightholder's Dad, Otto Skorzeny, rfs56trk), 71 guests, and 1 robot.
Topics128,038
Posts1,055,585
#201550 02/19/2006 5:28 AM
Junior Member
Junior Member
Hi there! I am new to the forum. smile I also have a queastion to ponder. I have been offered a 1941 Chevy one ton dump by a friend of my dad's for $450. The truck is still pretty solid, but someone stuck in a F*** 390 V8 and 4 speed tranny years ago. I have a 216 I can use for it with a bell housing swap and if I find a chevy 4 speed to fit in it. My question is this: This truck has 18 inch wheels and tires and it has a flat frame in the back instead of the humped up frame most 1 tons have. Also, the rear end under this truck is pretty hefty. My dad has helped work on this truck several times over the years and he thinks it might be more of a ton and a quarter instead of just a one ton. Would this be possible? I do have some piccies of it if I need to post them and I am waiting for the owner to get back from florida so I can purchase the truck.
#201551 02/19/2006 5:35 AM
Sim,
Would you have the serial number? We should be able to figure it out with that.
Welcome to the bolt page. It is always nice to have another 41-46 fan on here...
Also...dump that dorf engine grin
#201552 02/19/2006 5:36 AM
sounds like a good find. odd that someone put a 390 in it, but that is a solid working motor. It would be cool if you put a 216 into it. I think that any old truck is worth about what you are paying, espescially if that is what you want. go for it and have fun. welcme to the stovebolt page.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#201553 02/19/2006 8:07 AM
I suspect any Chevy/GMC transmission up to the mid 60's would work;Fumblin'46 would be more help on that. Providing it's in decent running order,you can probably sell the 390 for enough to buy all the replaceables for your 216 install(clutch,water pump,tune up,fuel pump,carb kit,alternator conversion,etc.),maybe a tank of gas,too.Good find! Enjoy!
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#201554 02/19/2006 9:04 AM
if it is all ready a v8 how about a chevy v8
#201555 02/19/2006 9:48 AM
Welcome simbalion!! I dont think you can go wrong at that price.
Hobert
"The Lord is my shepherd"
#201556 02/19/2006 5:27 PM
Welcome aboard! Good luck with your new rig sounds like you got it at a good price.
#201557 02/19/2006 5:32 PM
Sounds like a great deal. I would go back original myself but V8 power has advantages. Good luck with the project.
Heres to us and those like us, theres darn few left.
#201558 02/20/2006 1:35 AM
Sounds like a good deal. Anything that runs, even if it's the wrong motor, should be worth that much. Go for it!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
#201559 02/20/2006 3:04 AM
Junior Member
Junior Member
Thanks for the warm welcome! I will have to get the serial number next time I see the truck. I hope that is soon.
#201560 02/20/2006 3:33 AM
Welcome to the 'Bolt!
Daily Driver 63 C-10 LWB Fleetside
#201561 02/20/2006 2:58 PM
Junior Member
Junior Member
Welcome simbalion!
Davey
#201562 02/22/2006 5:20 PM
Junior Member
Junior Member
#201563 02/22/2006 5:47 PM
looks like a ton and a half, w/ the bigger front fenders, might even be a 2ton w/ that nice lookin dump - if yer interested in that kinda truck don't pass it up!
#201564 02/23/2006 4:28 AM
Junior Member
Junior Member
The original wheels on the rear are 8 bolt 18 inchers. Someone changed out the 18 inchers on the front for later 16 inch rims. I have seen other earlier one tons with 18 inch wheels and tires. The dump bed looks to be original.
#201565 02/23/2006 7:25 PM
Welcome to the 'bolt. Cool old truck. Lots of character! Hard to tell really without the body serial number. The ID plate should also have the GVW. With the 8 lug bolts I'm guessing 1 ton. wink
Professional Novice
#201566 10/17/2006 1:35 AM
Junior Member
Junior Member
A little correction on the 1 ton. I have come to find out that it is a 1946. I am going to finally try and buy it soon.
#201567 10/17/2006 2:10 AM
All Chevrolet 4 speed transmissions from 1933 to 1947 will interchange as there is very little difference in them other than casting numbers.
34 & 35 trucks are the greatest
#201568 10/17/2006 6:30 AM
Junior Member
Junior Member
That's good to know. The problem around here is finding parts from any make of truck in that era. Too many had the original running gears ripped out for modern parts. You probably see more 49 and later Chevys around here than the earlier ones for some reason.
#201569 10/17/2006 12:10 PM
1 tons and up had a "flat frame" in back with no hump over the rear axle... so that makes it correct for being 1 ton or larger.
The 18" wheels... well I'm not a pro on this year truck but that usually means it's a 1 1/2 or 2 ton truck.
Nice looking truck. For $450 it's worth it, IMHO.
Figure out what you want to do with it. If you want an original restoration, then you have lots of rare parts to find and buy (big $). If you want a resto/mod then your parts will be cheaper and it will be a more user friendly truck for todays roads. If you want a hot rod... well sell it and buy a 1/2 ton.
#201570 10/18/2006 9:22 PM
Junior Member
Junior Member
I have seen other 1 tons from the 30s thru even the early 50s that had 18 inch tires. Dodge is the earliest I have seen to use the more standard 16 inch arrangement. These skinny 18 inch tires do give the truck a neat look and a 16 inch wheel will not fit over the rear brake drums. The at least lets me know the rear end housing is original.
