0 members (), 114 guests, and 1 robot.
Topics128,105
Posts1,056,541
Members48,448
Junior Member
Junior Member
Hi;
I'm thinking about installing a trailer hitch on my 1954 3100. Is there one available to purchase or do I have to make one? I have seen some universal types but it looks like there might be a clearance problem with the spare tire. Any ideas?
Thanks.
Rich
I wonder if a few of the vintage truck suppliers could point you to the right direction. I know if you had a step bumper they always seem to have a provision for a trailer ball. You might try some of the vendors on our links page.
I have an old one on my truck stamped Valley RV but I'm pretty sure its no longer made. The best way to do it is to find a welding shop and have them make you a reciever hitch that fits well, a bumper hitch isn't really very safe.
Paint & Body Shop moderator
You might look at Joe's truck:
www.joefuchs.net/gallery/gallery.php?eventid=1
btw, whatcha gwana tote with it? I made a really big industrial one for my 1 ton, but it has to tote heavy stuff every now and then.
I'm kinda wondering the same thing as Rich... I installed a rear bumper on my 56 Stepside. It has a flat "step" in the middle of it. Any thoughts if I drilled a hole there for a ball?? I don't see myself towing anything major. A small food concession trailer perhaps....
Larry Bear
55.5 Chevy 3100 Panel
Don't know if it will help but check out Vintage Truck for October 2005, on page 18 there is an article entitled 'Trailer Hitch for Vintage Towing'.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Larry Bear...Check your email
Shoop
Thanks Olblu & Shoop!
Larry Bear
My '46 1/2 ton has a solid bar about 3" thick for a rear bumper with a flange sticking out the center with a hole in it for a ball hitch.
It held a 14" car trailer with a Farmall Super M (with a loader) on it just fine.
Guess my springs are still good, since it didnt lower the back of the truck all that much.
Grandpa made a hitch when he put the flatbed on. It's welded onto the bed's frame and bolted onto the truck's. It's not going anywhere.
When I put the box on, I'm not sure how I'm gonna pull that off. I may get a class III receiver hitch off of a junkyard denizen and modify/cannibalize it to make it work with the truck.
It should be interesting, whichever way it goes.
Hey Rich,
Here are some pictures of the 55.1 1/2 ton I owned for a while. Sorry I couldn't get closer to the bumper but I no longer own the truck.
[img]http://img.photobucket.com/albums/v374/55chevy/1955b.jpg[/img]
[img]http://img.photobucket.com/albums/v374/55chevy/55Deer.jpg[/img]
Hope that helps.
-Chris
Chris 1955FirstSeries
My 61 has a step bumper with a 2.5" ball mounted directly to it. It is pretty strong. I am not going to haul a big boat on it, but it totes a small trailer with yard waste or a 4 wheeler just fine. I am not sure if it is an "advisable" setup and I am sure someone will clue me in. It works for what I use it for, it is a nice enough set up.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
Junior Member
Junior Member
Hi;
Just a quick note to update. I have tried the major old truck sources (LMC, Chevy Duty, etc.) and also the major hitch manufacturers (Reese, Draw-Tight, etc.) No one offers a ready-made. But I did get good ideas from all of you and so will make one.
Thanks.
Rich
On my 63 I'm going to mount one just behind the license plate so it will be hidden until needed. I'll just mount an old GM fold down license plate frame to access the hitch. Just a thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I just bought a good one from Orshelns Farm supply this week. Just measured how wide my frame is and got one the same size. They had it in stock.Six holes drilled in the frame and six bolts and I was done.It was predrilled for a late model truck but it worked real good on my 54 one ton GMC.
I like old trucks
Check this link out. This is the receiver hitch I built for my 52 GMC.
http://oldgmctrucks.infopop.cc/groupee/forums/a/tpc/f/294006236/m/1731028971/r/1731028971#1731028971
I modified one off a Dodge caravan to fit my 64. The drop was just right. Just had to narrow it.
V
V Offline
Get a minimum of Class III (3) hitch if you intend to pull a car trailer.
Draw-Tite usually has something to fit everything, and are pretty good quality. You'll likely need to measure the distance between framerails, and match it to one of their models (their parts books don't go back that far). I have one on my 66 because I pull a trailer fairly regularly.
I have one I took off a 62. It is the square receiver type and bolted to the frame. some of it is probably homemade but it looks ok. Make me a offer and come and get it in Lansing mi,(not to far from toledo)
First try a used car dealer,any dealer for a hitch.They take them off the cars before they sell them to tell you the little old lady only drove it to sunday school.Once you got the hitch,go to the hardwear store ,buy some square channel,cut to size.the lenight is 46" on a 53 1/2T.This will give ya a class 5 hitch Reese hitch 2"
dan-pa
