1 members (klhansen), 173 guests, and 3 robots.
Topics128,080
Posts1,056,317
Members48,442
#187180 08/09/2005 9:45 PM
Ok, can't take the heat anymore...I have stock recirculating heater in my 50 3100 and am looking for a shut-off valve to keep water from radiator going to heater core. Is there an aftermarket item that I can get at any FLAPS that will do te job? I'm assuming that is what a Ranco (?) valve does, or is there an item that some of the specialty houses (chevy duty, carter) carry that I'm missin?
Sweatin in Southern IL,
Chuck
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#187181 08/09/2005 9:53 PM
2 Offline
blue 50 You can go to any hardware store and get a ball cock valve and screw it into the water pump outlet and just shut it off under the hood during the summer.
#187182 08/09/2005 10:22 PM
Riding in the Passing Lane
Also you can get an inline heater valve at a parts store & hook a cable to it. Be shure to put any valve on the inlet side. smile
1972 Chevy c10 Cheyenne Super
#187183 08/09/2005 10:34 PM
Bless ya'll, been wondering why I had heat in the summer..I think I'll just get one that goes in the heater hose with a cable operation..Thanks, Steve
#187184 08/10/2005 12:17 AM
Insomniac
Insomniac
Got one of those a few months ago... Have a look:
Heater
Gord 🇨🇦
1954 1/2 ton 235 4 speed
#187185 08/10/2005 12:27 AM
Auto Zone, 5 or 6 bucks. Works great
#187186 08/10/2005 12:35 AM
I wish that was the reason why my cab stays so hot,, no heater in mine but those fentons will put out a lot of extra heat............Fred
Redryder pix
My Hotrod
#187187 08/10/2005 12:50 AM
Insomniac
Insomniac
Fred, the reason you cab is so hot is that you live in Texas, where it's freaking boiling!!
Gord 🇨🇦
#187188 08/10/2005 1:12 AM
that is true too........Fred
Redryder pix
My Hotrod
#187189 08/10/2005 1:49 AM
Not as convenient but last summer before the drive to the left coast I simply looped the hose from the water pump to the manifold nipple bypassing the heater altogether. Looped the other hose between the two heater nipples to keep anything out.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#187190 08/10/2005 3:31 AM
I've used needle-nosed Vise Grips in a pinch,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#187191 08/10/2005 3:40 AM
Quote
[groans]
#187192 08/10/2005 10:56 AM
V
V Offline
I would go with the ball valve from the hardware store these are 1/4 turn valves and most are solid brass and are pretty nice looking when you pop the hood.
#187193 08/10/2005 12:12 PM
I've been wanting to do the ball valve application for years now. It's still on the to do list. Would only one valve be required? I had been thinking of installing one in each hose line.
Bruce
#187194 08/10/2005 1:54 PM
Thanks guys, I am leaning towards the brass ball valve because of looks. any guess what size is needed?
Gord, nice pictures, got any more?! guess you might be using your heater more than me livin in the great white north
Chuck
Blue 50
1950 3100 w/57 235
#187195 08/10/2005 7:54 PM
I could take a picture of the installed valve if you want but it wont be too exciting; just an inline valve with the push-pull cable attached...
I wonder about the ball valve idea you guys are discussing. You would have to get out of the truck (probably in pouring rain) and open the hood when you want heat? Then it would get too hot and out you goo again. I know you could open the window to regulate the heat, but then you would have the rain blowing in...
Gord
#187196 08/10/2005 10:50 PM
You would only open the ball valve in the fall and close it in the spring. You wouldn't have to open and close it daily.
To be long remembered as he's cruising in
The Passing Lane
#187197 08/11/2005 12:13 AM
Insomniac
Insomniac
Barry: That sounds like planning ahead! eek
Gord 🇨🇦
#187198 08/13/2005 2:27 PM
wanted to give you guys an update... picked up an inline valve from Napa, it's a Balkamp #660-1413 for $23. It's a screw-down type and not cable operated. Last night drove 20 miles roundtrip to a local cruise night in Herrin, IL and cab was much cooler, well as cool as it can get with all the holes/openings I still have to cover at 90+ degrees. Next project will be sound deading/heat blocking...
Blue 50
1950 3100 w/57 235
#187199 08/13/2005 4:13 PM
I just got one from Carquest. Much cooler cab now. What a difference on long rides. smile
#187200 08/14/2005 2:30 AM
2 Offline
Bruce K you only need one ball valve in your heater hoses. It needs to be in the outlet side of the water pump.
#187201 08/14/2005 4:35 AM
Why does it need to be on the outlet side? Just curious. Always want to learn sumpin new. wink
#187202 08/14/2005 9:44 AM
The factory used a non-cable operated valve for recirculating heaters. Pop the hood and turn the handle if you want heat. One of the MANY reasons I like fresh-air heaters better, especially the '54 version that can do fresh air or recirculating.
1954 GMC De Luxe COE
#187203 08/14/2005 11:24 PM
The hose going to the water pump is the return hose from the heater. The inlet to the heater comes from below the therm. or on the intake on a V8. You want the valve on the inlet to the heater so you won,t have excessive pressure on the heater core. smile
#187204 08/14/2005 11:28 PM
Hey Wrench, I'm glad you got in on this, because I was going to buy one, and thought it went into the hose from the water pump..Thanks much, Steve
#187205 08/15/2005 12:24 AM
Well..I always like to do things twice just for practice!! Look's like I will be switchin' hoses.
Wrench, you mentioned a v8, would the inlet on my 235 still come from the thermostat to heater and then return from heater to water pump??
Blue 50
1950 3100 w/57 235
