5 members (frogfarmer, Youngin' Tut 59, Phak1, jay d, 1 invisible), 72 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,469
Socket Breaker
Socket Breaker
hiya folks...
I was just curious what wheels the 60-66 trucks guys have on their rides with the original 6 lug wheel pattern. Aftermarket wheels, wheels off another year chevy truck or car... whatever... I'm merely curious.
Also curious, if you still have drum brakes or disc brakes with your current wheels.
It seems I have 2 wheels that are '65ish and 3 that are 55-59ish.
Anyway... just wondering...
-W
On my '60 I too have the 6 lug wheels and 4 drum brakes. I choose to return the truck stock. It seemed easier that way for a first time restorer.
I might change them leter if I se the need.
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Anonymous
Unregistered
Anonymous
Unregistered
I think my 60 parts truck has original/stock wheels. But my 64 driver has some eagle alloy 15 inch rims that the PO put on. (paid as much for the truck as he did for the rims grin )
Junior Member
Junior Member
6 lug rally wheels off a 73-87 4x4 truck. They are the proper battern and backspace and are 8 inches wide.
Tender caretaker of antique tractors and old trucks.
Junior Member
Junior Member
I have had 6 Lug Rally and Steel 10" wide wheels on my 66. The wheels from 88-up trucks will not fit 60-87 2WD or 4WD Trucks. I already tried that.
I have the original stock rims on my '66.
Junior Member
Junior Member
I've got some 6 lug mag wheels that came with my 62 stepside. It's in the gallery.
Priorities make dreams happen.
i have smoothies.. they were on there when i bought it
15x8 K-Blazer wheels. Everyone seems to like 'em.
JS
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
Socket Breaker
Socket Breaker
cool folks...
everyone feel free to keep posting...
-W
6 lug Rallye Wheels with ECE front disc brake conversion. Kind of blah looking to me, but they were on the truck when I bought it.
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
Junior Member
Junior Member
I just bought some nice chrome steel wheels (15's) with baby moon hub caps from the used bin at Les Schwab tires for my 64 C10. The truck has has the original 6 lug drum brakes (although one drum is 4 lug!). I think they make they really make the truck look sharp even though the rest of it is a rust bucket. I am keeping the 6 lug wheels because I intend to keep this truck as close to stock as possible with a mild 60's/70's performance look - whatever that is. My next trick is for the brakes to work. Until then I must admire my ride while parked!
powder coated and pinstriped, Standard JEEP 7'' (they look like rally rims)
beauty rings and original early 50's hubcaps.
http://www.speedprint.com/Deves50/hubcapclips.php
cheers
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
Woog,
In my opinion nothing looks better than a set of 15x8 grey painted Chevy rally wheels on the 60-66 trucks. Of course you need the stainless trim rings and 255/70R15s make a nice setup.
I have some sort of funky 7 inch wide aluminum centerlines on my truck (the same ones I had when we did the meet back in '03. I have two additional sets of wheels, both are 15x8 6 lug rallys. One set I'm going to have blasted and painted and thrown on the truck - the other set you're more than welcome if you're willing to drive to Douglasville to pick up.
They will need blasting and painted. wink
-ftyler
Socket Breaker
Socket Breaker
** boing **
any more folks with wheel ideas?
-W
I like Ralley wheels also, burb wheel these have a 3inch stainless trim ring. I became a believer in them working at a tire store years ago. They are tough, cheap, easy to care for, backspacing is good for older trucks.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Mine's not a '60-'66. but i've got the Blazer Ralleys on my '55, too. Nice thing is that they will fit all the way back to at least '47 without any fitment issues.
Bill Burmeister
I am also running the 1976 Blazer 15"x8" Ralley wheels under my 55 Cameo, but I am also using the 4x4 axles. I am in the process of re-installing the original front and rear axles but will keep the wheels, as I am planning to run disks on all four corners.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
I have a set of 15" chevy rally's, not sure what they came off of. The center caps had 4x4 logos on them when I got the truck. I ditched those and am running capless right now. I think that they must be from a newer 4x4 chev...not sure though. Mine are painted silver with the stainless beauty ring. I really like how they look. I think that they are 8 inches wide, cause my 9.5 inch tires don't "baloon" very much on them. Good enough for now.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
Woog:
Good post topic. I have a number of different wheels on my fleet of '64-'66 Chevy trucks, but my all-time favorite is the Rally truck wheels. My first '66 Chevy C10, in '81 had a brand new set of Rally truck take-offs from my father's '81 Chevy 1500 4x4. Many of the wheel combinations are shown in my signature line of my Gallery entries.
Tony
I started with the original skinny 15" split rims with 7.00 X 15 tubes and tires. Now I have 16" wheels - 7" rear, 6" front. They were custom built by Stockton Wheels utilizing old centers that match my originals. I had them powdercated and am using my original hubcaps. My new tires are Continental 235 75R16s. Here are before and after pics. http://client.webshots.com/client/c...photoID=2515435560071636143&source=c
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
My 62 has Weld alum wheels and caps(see in gallery) 16" 235-55 front and 255-55 rear. am going to change to larger wheels when things come together.
Junior Member
Junior Member
1 Offline
My 63 has 15" alumnum directional rims.I recently purchased 20" boss wheels
My driver has 6 lug chrome modular wheels with drum brakes.The donor truck has 6 lug white spokes.Will most likely stay with the 6 lug but still undecided on the wheel as of now.
Current project . . . 1960 LB stepide Chevy
