2 members (Kilted54, UtahYork),
72
Mod | | | Forums66 Topics128,196 Posts1,057,392 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | hiya folks...
I was just curious what wheels the 60-66 trucks guys have on their rides with the original 6 lug wheel pattern. Aftermarket wheels, wheels off another year chevy truck or car... whatever... I'm merely curious.
Also curious, if you still have drum brakes or disc brakes with your current wheels.
It seems I have 2 wheels that are '65ish and 3 that are 55-59ish.
Anyway... just wondering...
-W | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | On my '60 I too have the 6 lug wheels and 4 drum brakes. I choose to return the truck stock. It seemed easier that way for a first time restorer.
I might change them leter if I se the need.
Jake | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I think my 60 parts truck has original/stock wheels. But my 64 driver has some eagle alloy 15 inch rims that the PO put on. (paid as much for the truck as he did for the rims  ) | | | | | Joined: Jan 2005 Posts: 24 Junior Member | | Junior Member Joined: Jan 2005 Posts: 24 | 6 lug rally wheels off a 73-87 4x4 truck. They are the proper battern and backspace and are 8 inches wide.
Tender caretaker of antique tractors and old trucks.
| | | | | Joined: May 2005 Posts: 19 Junior Member | | Junior Member Joined: May 2005 Posts: 19 | I have had 6 Lug Rally and Steel 10" wide wheels on my 66. The wheels from 88-up trucks will not fit 60-87 2WD or 4WD Trucks. I already tried that. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I have the original stock rims on my '66. | | | | | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | I've got some 6 lug mag wheels that came with my 62 stepside. It's in the gallery.
Priorities make dreams happen.
| | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | i have smoothies.. they were on there when i bought it | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | 15x8 K-Blazer wheels. Everyone seems to like 'em.
JS | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | cool folks...
everyone feel free to keep posting...
-W | | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | 6 lug Rallye Wheels with ECE front disc brake conversion. Kind of blah looking to me, but they were on the truck when I bought it. | | | | | Joined: Jul 2005 Posts: 1 Junior Member | | Junior Member Joined: Jul 2005 Posts: 1 | I just bought some nice chrome steel wheels (15's) with baby moon hub caps from the used bin at Les Schwab tires for my 64 C10. The truck has has the original 6 lug drum brakes (although one drum is 4 lug!). I think they make they really make the truck look sharp even though the rest of it is a rust bucket. I am keeping the 6 lug wheels because I intend to keep this truck as close to stock as possible with a mild 60's/70's performance look - whatever that is. My next trick is for the brakes to work. Until then I must admire my ride while parked! | | | | | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | powder coated and pinstriped, Standard JEEP 7'' (they look like rally rims) beauty rings and original early 50's hubcaps. http://www.speedprint.com/Deves50/hubcapclips.php cheers
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
| | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Woog, In my opinion nothing looks better than a set of 15x8 grey painted Chevy rally wheels on the 60-66 trucks. Of course you need the stainless trim rings and 255/70R15s make a nice setup. I have some sort of funky 7 inch wide aluminum centerlines on my truck (the same ones I had when we did the meet back in '03. I have two additional sets of wheels, both are 15x8 6 lug rallys. One set I'm going to have blasted and painted and thrown on the truck - the other set you're more than welcome if you're willing to drive to Douglasville to pick up. They will need blasting and painted. -ftyler | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | ** boing **
any more folks with wheel ideas?
-W | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I like Ralley wheels also, burb wheel these have a 3inch stainless trim ring. I became a believer in them working at a tire store years ago. They are tough, cheap, easy to care for, backspacing is good for older trucks. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Mine's not a '60-'66. but i've got the Blazer Ralleys on my '55, too. Nice thing is that they will fit all the way back to at least '47 without any fitment issues.
Bill Burmeister | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I am also running the 1976 Blazer 15"x8" Ralley wheels under my 55 Cameo, but I am also using the 4x4 axles. I am in the process of re-installing the original front and rear axles but will keep the wheels, as I am planning to run disks on all four corners. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I have a set of 15" chevy rally's, not sure what they came off of. The center caps had 4x4 logos on them when I got the truck. I ditched those and am running capless right now. I think that they must be from a newer 4x4 chev...not sure though. Mine are painted silver with the stainless beauty ring. I really like how they look. I think that they are 8 inches wide, cause my 9.5 inch tires don't "baloon" very much on them. Good enough for now.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Woog:
Good post topic. I have a number of different wheels on my fleet of '64-'66 Chevy trucks, but my all-time favorite is the Rally truck wheels. My first '66 Chevy C10, in '81 had a brand new set of Rally truck take-offs from my father's '81 Chevy 1500 4x4. Many of the wheel combinations are shown in my signature line of my Gallery entries.
Tony | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I started with the original skinny 15" split rims with 7.00 X 15 tubes and tires. Now I have 16" wheels - 7" rear, 6" front. They were custom built by Stockton Wheels utilizing old centers that match my originals. I had them powdercated and am using my original hubcaps. My new tires are Continental 235 75R16s. Here are before and after pics. http://client.webshots.com/client/c...photoID=2515435560071636143&source=c | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | My 62 has Weld alum wheels and caps(see in gallery) 16" 235-55 front and 255-55 rear. am going to change to larger wheels when things come together. | | | | | Joined: Mar 2007 Posts: 20 Junior Member | | Junior Member Joined: Mar 2007 Posts: 20 | My 63 has 15" alumnum directional rims.I recently purchased 20" boss wheels | | | | | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | My driver has 6 lug chrome modular wheels with drum brakes.The donor truck has 6 lug white spokes.Will most likely stay with the 6 lug but still undecided on the wheel as of now. | | |
