11 members (Woodcmiami, Hotrod Lincoln, WICruiser, KCMongo, TexasJim50, Bill Hanlon, MNSmith, Chip O, LAROKE, Southerntruck, 1 invisible),
72
Mod | | | Forums66 Topics128,032 Posts1,055,523 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | I expect to have my 'new'(to me) 66 1/2 ton on the road by this weekend. With this I'll be able to find out part of my question as to how much will the engine wrap up at 60mph. I may be jumping the gun here but IF it whines too much, would putting oversize tires (just a little taller) be a viable solution? It currently has LT235/75R15 tires. I realize this would make the speedo inaccurate, but that doesn't bother me. Will bigger tires make it unstable at 60mph or really mess up the handling? Thanks in advance.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | My 64 with a 230, three speed manual, and 4:11 gears whines a little on the highway. I have small 15 inch rims with low pro tires (sorry I just got home from work and don't want to check exactly what my tires are  ). It humms at 60, my speedo is way off but that doesn't bother me. I only worry about overheating when I drive on the highway for a long time. One of my rear tires went soft so I took them off for a week and put some 16inch "whatever's" on it, the engine didn't rev as high on the highway and it felt just as stable at those speeds. Sorry, can't help you with the handling part. Good Luck. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't know about "viable solutions" Rance, but the larger the diameter of the tires, the lower the revs at a given speed, so it'll save a few RPM, tho not a lot - taller rear gears is what'll be the real solution
I put 700R15 Yokohamas on the 58 and the lower RPM was noticeable - looks like a truck now, steers easier too, and the narrower tread is actually better on wet roads, no stability problems w/ higher or narrower tires unless you've got suspension or steering issues outstanding
Bill | | | | | Joined: Oct 2004 Posts: 19 New Guy | | New Guy Joined: Oct 2004 Posts: 19 | Try to go with rear tires that have a diameter close to 30". Like the guy above I have 7.00-15 bias ply tires and the diameter is about 29.5" and they work well. Only other option is costly ring gear and pinion change or a late model rear end swap.
Rob Mathis
48 Half Ton with 235 & SM420
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | RANCE, go to www.randysringandpinion.com and www.1010tires.com and use their calculators to figure tire height and rpms. you can play around with calculators til you get the combo that will work for you. RON
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have a 64 230/3spd/3.73, been driving it 70 mph on the highway. I checked my speedo/odo w/a GPS. I have 225/75/15s all around. I was worried at first it would be too low geared but the six seems just fine, although it don't like going any faster than 75. Brian | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | When I was running the 230 in my 64, I had 31 x 10.5 x 15 tires on all four corners and ran 65+ for 20 miles every day. They also filled them huge wheel openings up better, Scott | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | My '66 C-10 has 225/75/15 radials on it, and rides well at 60-65 on the highway. I don't like the feel of this truck at speeds over 65.  | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | posted 13 July, 2005 14:37 -------------------------------------------------------------------------------- For Matching - Mating ... Engine, Rear End Gearing & Ratios, RPM's, Tire Sizing, Hiway Speeds, Matching Transmissions To ??, Cylinder Head Volumn , Fuel injecting, Compression Ratios and many other math calculations go to: http://www.smokemup.com/ ... find auto math
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Where's ftyler lurking at? Hmn...
-W | | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Thanks all for your input into this.
Rance
PS: Woogeroo, Every time I see one of your many helpful posts, it makes me sing at least the first line of "Back Off Boogaloo" by the Beatles. I'm sure you have a great story of how you came up with "Woogeroo".
Rance
| | | | | Joined: Jan 2005 Posts: 95 Member | | Member Joined: Jan 2005 Posts: 95 | I'm running 235/85 16's on my 69. I was told that this is the tallest combination. Handling is fine and the speedo is about 10 mph off at 65. Redcoat | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Here I is Woog! Rance, Everyone else has covered this well. I have a '66 stepside (that hasn't been driven in 6+ months, sadly enough) and I once had a 230/3 speed/3.73 gear combo. With my 235/70R15s its top cruising speed on the interstate was 65 mph. So I built a 292 and kept the same wheels/tires and rear end gearing, but added a 4 speed manual stick tranny, with 4th gear being overdrive. Now the truck turns about 1900 rpms at 60. And when I want to jump on the interstate, I have no trouble doing extended trips at 80 mph with the fast lane traffic, as the overdrive keeps the rpms at only 2600. My advice would be to drop in a 4 or 5 speed overdrive and be done with it. The "taller tires" solution is not going to take your truck from being a "high rpm/low speed" beast to an easy interstate cruiser. -ftyler | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | ftyler's truck has a nice sound to it also... vRoom.
ftyler, you betta drive that thing or it'll fall apart. I can volunteer to take it on a speed run.. ha ha ha.
-W | | |
