1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#185461 07/15/2005 3:52 PM
I expect to have my 'new'(to me) 66 1/2 ton on the road by this weekend. With this I'll be able to find out part of my question as to how much will the engine wrap up at 60mph. I may be jumping the gun here but IF it whines too much, would putting oversize tires (just a little taller) be a viable solution? It currently has LT235/75R15 tires. I realize this would make the speedo inaccurate, but that doesn't bother me. Will bigger tires make it unstable at 60mph or really mess up the handling? Thanks in advance.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
#185462 07/15/2005 8:16 PM
Anonymous
Unregistered
Anonymous
Unregistered
My 64 with a 230, three speed manual, and 4:11 gears whines a little on the highway. I have small 15 inch rims with low pro tires (sorry I just got home from work and don't want to check exactly what my tires are wink ). It humms at 60, my speedo is way off but that doesn't bother me. I only worry about overheating when I drive on the highway for a long time. One of my rear tires went soft so I took them off for a week and put some 16inch "whatever's" on it, the engine didn't rev as high on the highway and it felt just as stable at those speeds. Sorry, can't help you with the handling part. Good Luck.
#185463 07/15/2005 8:29 PM
don't know about "viable solutions" Rance, but the larger the diameter of the tires, the lower the revs at a given speed, so it'll save a few RPM, tho not a lot - taller rear gears is what'll be the real solution
I put 700R15 Yokohamas on the 58 and the lower RPM was noticeable - looks like a truck now, steers easier too, and the narrower tread is actually better on wet roads, no stability problems w/ higher or narrower tires unless you've got suspension or steering issues outstanding
#185464 07/15/2005 9:25 PM
Try to go with rear tires that have a diameter close to 30". Like the guy above I have 7.00-15 bias ply tires and the diameter is about 29.5" and they work well. Only other option is costly ring gear and pinion change or a late model rear end swap.
Rob Mathis
48 Half Ton with 235 & SM420
#185465 07/15/2005 11:08 PM
RANCE, go to www.randysringandpinion.com and www.1010tires.com and use their calculators to figure tire height and rpms. you can play around with calculators til you get the combo that will work for you. RON
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#185466 07/16/2005 3:19 AM
I have a 64 230/3spd/3.73, been driving it 70 mph on the highway. I checked my speedo/odo w/a GPS. I have 225/75/15s all around. I was worried at first it would be too low geared but the six seems just fine, although it don't like going any faster than 75. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#185467 07/18/2005 12:38 AM
When I was running the 230 in my 64, I had 31 x 10.5 x 15 tires on all four corners and ran 65+ for 20 miles every day. They also filled them huge wheel openings up better,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#185468 07/18/2005 6:03 PM
My '66 C-10 has 225/75/15 radials on it, and rides well at 60-65 on the highway. I don't like the feel of this truck at speeds over 65. eek
#185469 07/21/2005 6:33 PM
posted 13 July, 2005 14:37
For Matching - Mating ... Engine, Rear End Gearing & Ratios, RPM's, Tire Sizing, Hiway Speeds, Matching Transmissions To ??, Cylinder Head Volumn , Fuel injecting, Compression Ratios and many other math calculations go to:
http://www.smokemup.com/ ... find auto math
Jim & Caroline
#185470 07/22/2005 1:30 PM
Socket Breaker
Socket Breaker
Where's ftyler lurking at? Hmn...
-W
#185471 07/22/2005 1:45 PM
Thanks all for your input into this.
Rance
PS: Woogeroo, Every time I see one of your many helpful posts, it makes me sing at least the first line of "Back Off Boogaloo" by the Beatles. I'm sure you have a great story of how you came up with "Woogeroo".
Rance
#185472 07/23/2005 12:34 AM
I'm running 235/85 16's on my 69. I was told that this is the tallest combination. Handling is fine and the speedo is about 10 mph off at 65. Redcoat
#185473 07/23/2005 3:36 AM
Here I is Woog! cool
Rance,
Everyone else has covered this well. I have a '66 stepside (that hasn't been driven in 6+ months, sadly enough) and I once had a 230/3 speed/3.73 gear combo. With my 235/70R15s its top cruising speed on the interstate was 65 mph.
So I built a 292 and kept the same wheels/tires and rear end gearing, but added a 4 speed manual stick tranny, with 4th gear being overdrive. Now the truck turns about 1900 rpms at 60. And when I want to jump on the interstate, I have no trouble doing extended trips at 80 mph with the fast lane traffic, as the overdrive keeps the rpms at only 2600.
My advice would be to drop in a 4 or 5 speed overdrive and be done with it. The "taller tires" solution is not going to take your truck from being a "high rpm/low speed" beast to an easy interstate cruiser.
-ftyler
#185474 07/23/2005 11:33 AM
Socket Breaker
Socket Breaker
ftyler's truck has a nice sound to it also... vRoom.
ftyler, you betta drive that thing or it'll fall apart. I can volunteer to take it on a speed run.. ha ha ha.
-W
