1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | ok i know taht theres teh Advance Design or AD truck series.. and ive heard of Art Deco for other years... but what would a 1961 fall under?? did they have a name for tha series | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | They just call the 60-66 the V8 era in my "Cherolet pickups 1946-1972" book. | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Check out this link on the history of Chevy Trucks by Don Bunn http://www.chevytrucks.org/resources/history_of_chevy_trucks.htm 1947 – 1955.5 Advanced Design Series (AD) 1955.5 – 1959 Task Force Series (TF) Then Bunn tells us, “Model Series designations for 1960 were completely revised. The new system began with a letter prefix. For example, a "C" prefix indicated a conventional cab; a "K" indicated a 4 wheel drive model; a "P" model was forward control; an "L" was a low cab forward; an "S" was a school bus and an "M" was a tandem.” It is a really nice and informative article. K | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I did some research on the name of the 1960-1966 models, and came up with "MODERN V8" and "TRADEMASTER". Once I heard "PINCHED WAISTLINE" mentioned. Some call the 1964-1966 "SLANT WINDSHIELD" trucks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Doug57 - the Trademaster designation is for a particular 283 engine - there was also a Loadmaster - both started about 57 +/- and were used as long as the 283 I believe
any info I've seen indicates GM never used actual series names except for the AD and TF years
Bill | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | Maybe the 1960-1966 Pick-ups should simply be called "FIRST GENERATION C/K", since they were the first in the series that ran into the late 1990's. No other frequently used name really fits the description of these trucks well. | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | 1939 is among the first of the "SS" Chevrolets... Streamline Series
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've heard them called the "Advanced Engineering" trucks before, or something like that anyway, Scott | | |
