1 members (UtahYork),
80
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Greetings folks, Shown in the picture below is the shaft that goes from the tranny mounted PTO to the hydraulic pump on my dump truck. A couple of the u-joints (one is circled) are shot and the u-joint itself can't be replaced, they are integral to the yokes. Does anyone know who sells these? I would imagine they come in different configurations to adapt to different shaft diameters? Any help would be greatly appreciated!! Thanks, in advance!! [img] http://image20.webshots.com/20/7/31/12/215973112NanOqn_ph.jpg[/img] | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | I see you live in Colorado Springs, which if I recall is a pretty good size town. So is there a drive shaft shop there? How about a truck bed supplier?
The u-joints should be only pressed in to the yoke, and I can see that the yokes are held in place by set screws. If the u-joint is part of the yoke, then they should have those or be able to get them, or if you have to they could make a new shaft to work on your truck. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | burgie ...I,ve never seen one that had integral joints to the yokes,only fact. sealed units with no grease fittings. possible that p.o. welded them in. could have internal snap rings by the brg caps. if you cant get them apart with BFH and a vise, (heat wrench suggested), like Jolly sez, take whole shaft to a drive shaft shop or at least the joints off the shaft and they should be able to match up some thing for you  steve sr. ps that looks like a std shaft to me. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | What Jolly suggested... drive shaft shop... you could also ask around at 4x4 off road shops as when they get to modifying the ride height and things they have to have custom shafts made for strength/length or they modify the stock ones, depending on the situation.
my 2 cents.
-W | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Also try tractor supply houses, bush hogs, log splitters, etc. all use PTO shafts. Brian | | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Thanks for the feedback gang  ... I've done tons of u-joint replacements and I looked at the assembly, hoping I can merely pull it apart and replace the joint. But, I don't see any clips or retaining devices. In fact the journals on the bearing cups look like they are knurled, thus my description of being an "integral" part of the yokes... Hopefully I can find some replacements. I don't need them now but always am on the prowl for parts  | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There should be a thin inside snap ring. The u-joint kit is available at Carquest or Napa stores if you can get a parts man to work with you. The catalog has listings by demensions.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | A place you might be able to find a joint like that is Granger. They carry alot of industial stuff like that. | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | OOPS I spelled it wrong, it is grainger. I looked on there web site, but did not find anything like that. Might be better off getting a catalog sent to your house. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The farm and fleet stores in our area carry a variety of PTO joints and shafts. I would give them a try, Scott | | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Cool...finally found them on the McMaster-Carr website...
Thanks for the help folks!! | | | | | Joined: Feb 2004 Posts: 29,765 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,765 | Check with an industrial bearing supplier, or a farm supply like Co-Op. Most of those joint assemblies aren't repairable, just replace the whole assembly. I notice the joint you've circled doesn't have much support. The pillow block bearing that supports the shaft should be very close to the u-joint, or the joint will fail very quickly. I maintained a fleet of wreckers with shaft-driven PTO winches, so I've seen that problem frequently! Jerry
