8 members (Hotrod Lincoln, tclederman, 2-Ton, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom),
167
0
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 175 | I changed the oil in both my wife's car and my regular driver truck this weekend. I remembered some of the tricks I've heard of. I didnt do any but here are the one's I've heard.
1. Drain overnight so as to get every last drop.
2. Pour 1 quart of cheap oil through before replacing the plug so as to flush any lingering dirt.
3. Warm up new oil in shop microwave before adding to engine.
4. Fill oil filter with oil before screwing it on.
Any others?
Gravity - It's not just a good idea, it's the law.
| | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Yea, here's a few --------- 1) Dip your finger in the oil and coat it on the rim of the oil filter so it'll screw on easier.
2) After you pour out the first bottle of oil, get a pocket-knife and cut the bottom off. then leave that one in there, and pour the rest of the oil into that. It's like a home-made funnel.
Hmm what else... Thanks, I hadn't thought of some of those! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | number 1] should be warm engine well b4 draining to loosen the most sludge
Bill | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Bill - I like #3 - the part about the "shop microwave"? Wow!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Running a quart of oil thru there is just a waste of time & oil, same as overnight drain-if the oil is hot enough to burn your hand any dirt/metal etc. will be suspended in the oil. If it doesn't burn your hand,its not hot enough to change. Brian | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | I/m not sure if its the same every where, but here in Walmart they are selling oil in gallon jugs, so this one is good to use,
...first bottle of oil, get a pocket-knife and cut the bottom off...and pour the rest of the oil into that....home-made funnel.
I used this one myself just yeasterday. My 454 takes 7 quarts when empty, so I had to buy one gallon jug and two quarts, next time I'll get two gallons, as there was some kind of use tax that was the same on either the quart or gallon..... | | | | | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | I don't know why warming the oil is any good. I guess it will run out of the can quicker that way.
As far as pouring a quart of cheap oil....if you've already drained overnight (not necessary, IMHO), then every last drop of oil and dirt is already gone.
And are you planning to let it drain overnight AGAIN to get all that cheap oil out of your engine? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I thought the reason they went to plastic bottles was the quick homemade-funnel-w/pocketknife idea. Brian | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | One good thing to keep in mind is to use rubber gloves (surgical style) whenever you can. Putting your bare hands in used oil, gasoline, varsol etc. can lead to cancer, so studies indicate.
As a young guy I had my hands in stuff like that up to my elbows all the time. Growing up around a farm seemed to provide an environment for getting your hands in petroleum products. I worked around airplanes for a couple of years prior to flying them. We thought nothing of having our hands in varsol while de-sludging prop domes or cleaning other parts of engines. Over the years I always changed my own oil in vehicles and invariably got my hands covered. Gasoline was a quick way of 'cleaning up'.
Well, today I have Multiple Myeloma which just 'might' have a root cause from petroleum products.
So----especially you young guys---Use da gloves!!
Cheers, George | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | The problems of changing oil is over.When the old bones just can't take it anymore.Take your car or truck to a quick lub change station.With the price of a qt of oil going up everyday.There is not much of a savings,doing it yourself anymore.
dan-pa
| | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I have dumped a quart of diesel through it before I put the plug back in and it seems to clean out most of the gunk left in the pan. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | My problem with taking it to a quick change place is they don't know how to secure the oil filter on, or put the drain plug back in securely. I have had this problem twice, so I went back to doing it myself or having my latest mechanic do it when he's fixing other stuff already.
If I could find a good quick change place that did right, I'd take it to them.
-W | | | | | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | Funny you should mention that, Woog.....While leaving work one day, a red Porsche 9something passed in front of me to get onto the exit ramp. I remember the incident vividly because the car sounded as if it was about to come apart. Once I got on the interstate, I passed the car pulled over on the shoulder.... I asked him if he wanted a ride, and if he knew what had happened. He told me the car just stopped, and he tried to turn it over and it spun real fast (in his own words)....Come to find out, he had just left from getting his oil changed at one of the local quickie oil change shops. I looked under the car, and the bottom side was covered with fresh, clean oil. When the attendant at the oil change shop spun the old filter off, he didn't look to see if the old gasket came off with it. He spun the new filter back on, and as soon as the engine heated up, the old gasket slipped off and all the pretty new oil came out.
I change my own oil, and ALWAYS make it a point to check (usually about 3 or 4 times) to see if the old gasket came off with the filter. | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Take your car or truck to a quick lub change station.With the price of a qt of oil going up everyday.There is not much of a savings,doing it yourself anymore. Actually, I've noticed a huge gap between doing it myself and having a lube place do it. For example, I saw (on sale) an oil change for $15.95, and decided on doing it myself - for $8.56, the whole price. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I'm with Woogeroo ... those quick-change joints can do some pretty stupid things!
They forgot to put the plug back in on my buddy's rear end (no pun intended) ... these guys aren't mechanics and they don't care about the job they're doing (usually).
I'd never trust my truck to such places. Even pro mechanics -- I always inspect any job done on my truck when I get it back home, and I always find myself fixing something a mechanic did!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Up here those quick change places (I guess all service stations do it too) charge to recycle the oil cans, old oil and the oil filter. Plus extra for the shop rags. Those $29.95 oil changes can cost up to $40.00 with those charges and taxes. I can buy a 4 litre jug of Quaker State at Wally World for less than $10.00 and a Fram filter for about $3.00, plus taxes and container recycling fee. My whole oil and lube job will be less than $15.00. I bought a grease gun years back and do the AD trucks every 1000 miles as is specified. Furthermore I enjoy doing it. Our local recycling yard takes the old oil for no charge. | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I have a Fram Sure Drain on my truck. It works great when I quick connect to the sure drain with the vacuum system at work. It just sucks all of the oil out of my engine. I always make sure my engine is at operating temperature before sucking the oil out. Then, I use a pressurized oil tank to fill the engine with new fluids. This almost makes it fun to change oil!
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Here's my opinion on this subject. First I wouldn't drain the oil overnight, chances are most of the oil will come out of the main and rod bearings, making them start up dry. Second, I wouldn't dump any used (dirty) oil back into the engine, more dirt will stay on the topside than will be flushed out. If your oil is that dirty to begin with, change it more often. Third, I've never heard of pre-warming your oil before, I like it at room temperature for easy pourability. Fourth, filling the filter is a good idea as long as it mounts vertically, otherwise you're just going to make a big mess. What I do is drive the vehicle until full warm, pull the filter as soon as possible and let drain while preparing the new one. Grease or oil the new filter seal and install. Drain the oil from the pan and while it's draining I check the tire pressures, coolant level and washer solvent level. Then I put the oil in as soon as I'm done with the other checks. The engine is still hot enough to pre-warm the oil if that's what you're into and the start it up, check for leaks and recheck oil level. That's what I do anyway, Scott | | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | I quit using the local quick-change place (ain't mentioning names but their initials are Jiffy Lube) when I specifically asked them to check the hydraulic clutch fluid level on my Jeep Renegade . . . and I lost the clutch the next day because it was dry. | | | | | Joined: Oct 2003 Posts: 185 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 185 | I like those catch and carry oil disposal containers . I fashioned a cylinder/tube out of chicken wire that is just shy of the disposal container's diameter. I used more chicken wire to cover one end. When I'm done pouring the oil into the motor, I place that cylinder on top of the disposal container and turn the 'empty' plastic oil containers upside down in the cylinder. The excess drains into the oil container. Have any of you tried this? | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | As they say in McDonald land,Have it your way.I think I'll change may oil now.
dan-pa
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Jarge, things have changed, haven't they? The shop manual talks about using gasoline to clean the air filter element and also to loosen the glass from the rubber mounting in the vent window.
Fred | | | | | Joined: Jan 2000 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 175 | Yup I do the normal stuff like 48BigTrucks mentioned. I knew all those other things that I'd heard of sounded odd and wanted to see if there were any other "tricks" that I hadn't heard of yet.
| | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | Would not advise draining the oil overnight but if you do......Put a large note over the key switch to remind yourself or to alert your wife/son/daughter before you cook the bearings. Even better, pull the coil wire until you refill.
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | 4d9r what I do is put the oil bottle on the seat and put the key in my tool box. How many remember the racks they used to have at service stations which would hold about 6 recently emptied oil cans. The oil cans were mounted inverted on an angle and all the new oil which did not come out of the cans got drained into a new can. Those were the cans they opened with a vee shaped opener. Plus a smaller hole on the opposite side to let the air in. The good old days! | | | | | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | Jarge, good advice. I use Nitrile gloves all the time. In fact if I don't have gloves on I don't want to touch anything, and usually don't. My hands don't betray my occupation any more.
Anyone can make a mistake. I just bought a car for my daughter. The last thing they did after detailing it was a service. Then it came to me, supposely ready to go. I looked it over Saturday afternoon before she came to pick it up. The battery was loose, hold down bracket was installed backwards. Probably done by the PO as it was an Everstart battery. The engine had 1 quart too many in it. This is a Ford dealership that does a lot of work in these parts! Mike | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would never let the oil drain overnight. In fact I put in the plug & pour in some oil as soon as it has drained suficiantly. The oil pump can lose its prime & run the engine without pressure quite some time. I saw onetime a guy ruined his engine because the pressure never did come up. He just sat there gunning it trying to get the light to go out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | Norse, I use the same drain pan, works great. When I ran a big truck shop, we used those valves. Worked great, never had a problem. | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | I use my wifes turkey baster to get the oil out of my filter canister. Works pretty well, even though it takes a few minutes. I wipe the canister out with a clean rag before refilling. To dispose of our used oil, I converted my dads wood burning shop stove to burn oil. I mounted a reservior to the shop wall and tapped in a ball valve to the bottom side and attached that to a 1/2" copper line. The copper line is wound around the chimney pipe a few times and then tapped into the top of the stove. I layed a 1/4" thick splash pan in the bottom of the stove where the oil can drip and splash on it. Then you just start a small fire with paper and adjust the valve to where it is just dripping a drop every second or two. After it warms up good, it makes a whooosh at every drop and keeps a roaring fire going all day. Its cheap and uses up all the used oil we generate. Ralph | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I assume its common knowledge cause nobody mentioned it, but I will. Park on level surface. Thanks to all for the good tips.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Nov 2004 Posts: 122 Member | | Member Joined: Nov 2004 Posts: 122 | Definitely check for the filter gasket, I lost 5 quarts of fresh pennzoil one time courtesy of a cheap Fram gasket that decided to stay on the motor instead of the old filter...thankfully it happened in the driveway | | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | If you dont have an oil catch basin use an empty liquid detergent Tide container (2.5 gal.). I cut the top off and use it to catch the oil. It still has the handle for carrying and you can refill the empty oil bottles using the dispenser button on the container. | | | | | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | I use my old oil to keep the deck on my lawnmower from rusting out. Every time I get done cutting grass, I wash the deck off with water, let it air dry, then use a paintbrush to slap some used oil on the underside of the deck. Lasts for years.
Just make sure you don't park it somewhere you don't want oil stains...... | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I painted the inside of some flower boxes with used oil. Flowers are growing great and the box still looks like new. No I wouldnt add it to my garden or anything like that. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | One thing we all agree on.stay away from those quick lube places. | | |
