Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#161929 06/06/2004 5:35 PM
Junior Member
Junior Member
' Offline
I need to repair or replace my windshield wiper motor. How in the world do you get to it? I have a bad back so find it very difficult to try to reach from under dash. Can it be reached by taking out the speed odometer gauge or gauge cluster? If so, how in the world do you get them out!?!? I'm new to all this so bear with me.
Tony
#161930 06/06/2004 6:32 PM
behind the gauges you'll find 4 bolts attached to the dash on each gauge there are nuts on these you just take off the nuts and a little pressure they should come right out (or at least thats the way they come out on my 52 and welcome to the 'bolt
#161931 06/07/2004 1:59 PM
There is really not any good way to get to the wiper motor without getting yourself into a very uncomfortable position in the floorboard of your truck. I am restoring my cab now and it is a pain to get up under that dash. I got some old pillows and blankets to make it a little less painful. You have to get under there to get the guages out so you really haven't saved yourself anything. I'm dreading having to run the wiring harness under there as that is my next step.
#161932 06/21/2004 5:39 AM
These guys are right,except I got my wiper motor out and the new electric in without pulling the gauge cluster.either way it is a royal pain in the neck,arm,back,butt,you name it,,,Good luck.
Every man builds his world in his own image.
He has the power to choose,but no power to escape the necessity of choice.
If he abdicates his power he abdicates
his status of man....John Gault
#161933 07/09/2004 10:19 PM
I got in the truck from the passenger side and lay on the floor. I reached up and undid the old motor from that position. I also removed the speaker grille plate which made it easier to eyeball things before I got onto the floor. Of course if you have a floor shifter then it is more difficult. I did bang my head a few times on the pedals and I think my neighbors kids learned a few new words. Some people actually remove the whole seat assembly and put a plywood board across what is left. Cushions maybe!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#161934 07/10/2004 11:31 AM
I pull the seat out and lay on the floor. Still a pain, just not as bad. Taking out radio grille helps too, also the radio blank out plate. Floor shifter would make it tougher.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
#161935 07/28/2004 6:53 PM
I replaced mine with an electric one from Chevy Duty. Got it in without taking anything else out, but you have to be kind of a contortionist to do it. Bifocals don't help, either!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
#161936 08/10/2004 9:15 PM
Everything above plus unbolt the clutch and break pedals and take out.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
Moderated by  ndkid275, Phak1
