| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 35 Junior Member | | Junior Member Joined: Apr 2004 Posts: 35 | I need to repair or replace my windshield wiper motor. How in the world do you get to it? I have a bad back so find it very difficult to try to reach from under dash. Can it be reached by taking out the speed odometer gauge or gauge cluster? If so, how in the world do you get them out!?!? I'm new to all this so bear with me. Thanks Tony | | | | | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | behind the gauges you'll find 4 bolts attached to the dash on each gauge there are nuts on these you just take off the nuts and a little pressure they should come right out (or at least thats the way they come out on my 52 and welcome to the 'bolt | | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | There is really not any good way to get to the wiper motor without getting yourself into a very uncomfortable position in the floorboard of your truck. I am restoring my cab now and it is a pain to get up under that dash. I got some old pillows and blankets to make it a little less painful. You have to get under there to get the guages out so you really haven't saved yourself anything. I'm dreading having to run the wiring harness under there as that is my next step. | | | | | Joined: Mar 2002 Posts: 7 Member | | Member Joined: Mar 2002 Posts: 7 | These guys are right,except I got my wiper motor out and the new electric in without pulling the gauge cluster.either way it is a royal pain in the neck,arm,back,butt,you name it,,,Good luck.
Every man builds his world in his own image. He has the power to choose,but no power to escape the necessity of choice. If he abdicates his power he abdicates his status of man....John Gault
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I got in the truck from the passenger side and lay on the floor. I reached up and undid the old motor from that position. I also removed the speaker grille plate which made it easier to eyeball things before I got onto the floor. Of course if you have a floor shifter then it is more difficult. I did bang my head a few times on the pedals and I think my neighbors kids learned a few new words. Some people actually remove the whole seat assembly and put a plywood board across what is left. Cushions maybe! | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | I pull the seat out and lay on the floor. Still a pain, just not as bad. Taking out radio grille helps too, also the radio blank out plate. Floor shifter would make it tougher.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I replaced mine with an electric one from Chevy Duty. Got it in without taking anything else out, but you have to be kind of a contortionist to do it. Bifocals don't help, either!! | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Everything above plus unbolt the clutch and break pedals and take out.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
